Need a dry sump pump recommendation
  • Vap8102
    • Jun 2017
    • 6
    I’m looking at the 5 stage Peterson R4. Is it dependable? High maintenance? Bulletproof? Something better out there?
  • TALON75
    • 887
    As long as you don't hurt the motor they are good. Once anything runs through them they are basically junk, as a rebuild is only 200 less than a new one. The aluminum gears are not good at having anything pass through them. I have always perfered Barnes(and the old Peterson pumps), as they are pretty easy to clean and rebuild and each stage is about 70 bucks if you need to replace.
    www.RACE91.com
    • hucktyson
      • 1903
      If you want an amusing conversation call Roy Johnson of Johnson high performance pumps. He will convince you that you only need 15psi at wide open throttle
      • hucktyson
        • 1903
        And he refers to a dry sump tank as a " hareseeevawwww " and says it a few times a sentence
        • petesbuyin
          • 56
          I agree with Talon. R4 pump is a very high quality piece but it will not tolerate even minor debris through it. I have had very good results with the old style Peterson or a SCP with 1.450 bodies.
          A droop rule is like infield tractor tires, everyone knows it's stupid, but they still keep doing it.
          • grt74
            • Jul 2009
            • 1380
            wulff pumps, he is very easy to work with and his pricing is great too, very very knowledgeable, never had an oil pump issue, broke a rod one time (NOT THE PUMPS FAULT) all of that ran through the pump STILL HAD OIL PRESSURE
            • fastford
              • 4059
              i have had some dealings with them all , like said , if engine took care of , they will all perform good , me personally , i still prefer the old weaver bros. or SCP , which is a clone of the weaver , there less expensive and easier to work on to me...JMO.....
              • Vap8102
                • Jun 2017
                • 6
                That’s what I was guessing on the R4 - that the aluminum gears would be high maintenance. Is there any proof out there on why one pump is better than another?
                • hipower17
                  • 643
                  i'd say any of them are good and i agree with talon's comment
