high travel rf/lr
    #46
    My guess: Super super super soft LR spring rate and super super super high LR shock compression. The car had sat on all 4s so long that the LR frame rail was on the ground. Crew guy lifted the car (easily, by the way, because of the super soft LF spring rate) so that that the shock could hold the car up long enough to get him over the pit lift as he pulled out.
    If he sits too long in the line up shoot and the car ends up down that low he'll just crank the wheel as he gases up to make sure he gets LR hike. Kind of knowing how Rumley thinks, he probably put little wheels on the underslung to make sure it doesn't drag bad but it would still potentially catch and damage a pit lift.
    • riddle28
      • Apr 2010
      • 1088
      #47
      imagine what theyre able fudge out of the body when its like that.
      • mickley.28
        • Feb 2017
        • 19
        #48
        That shows you how much these guys care about scale numbers. With the left rear and right front that soft and the car sitting like that he probably had -200lbs of wedge in the car in the static state. I assume they’ve doing super soft left and right front for a couple reasons. 1 - to lower rear deck height so they can have high dynamic ride height which equals more downforce and 2 - to help soften the left rear over the ruff parts of the track to keep the tire from braking traction (basically what he was doing with the Rumley device).
          #49
          We never really cared about scale numbers, it was just all we had to compare notes. We didn't realize it. Lol.
          • Jking24
            • Oct 2017
            • 1519
            #50
            Agreed 100% Long before smashers came into the dirt seen i realized that attitude was everything. I knew scales didn't mean a thing but scaling was all we knew
