Dry sump belt?
  • bullittwrench
    • 228
    Dry sump belt?
    My Bert flywheel has a 21 tooth gear on it for the belt. I bought a pump with a 30 tooth gear on it. Both HTD. Is this correct and what size belt do I need? Thanks
    • 2020
    That's pretty fast, typically your in the mid 50% range on speeds but depends on pump and pump size. I'm going off memory here and my be off as it's been a while, 40 tooth upper = 580MM belt length
    • Punisher88
      • Nov 2014
      • 495
      If your asking about the teeth per inch that's what you need to check. Not the overall tooth count.
        • 2020
        I believe he's asking if a 30 tooth pulley is the correct size for the right pump speed and if it is, what's the belt length needed when mounted on a typical bell housing.
        Teeth count sets the pump speed, he'd be turning it like 70% engine speed which is very fast for a typical dry sump. The common upper pulley size is generally a 40 tooth pulley when using mounted to a bert/brinn type 21 tooth lower.
        • Punisher88
          • Nov 2014
          • 495
          Ah, I see.
          • TALON75
            • 887
            With a 40 tooth it's pretty typical to run a 640mm belt, but still gonna depend on bell housing mount and oil pump mount.
            www.RACE91.com
            • bullittwrench
              • 228
              It’s a Bert reverse set up. I didn’t think 30 teeth on the pump seemed correct.
