a question
  • hipower17
    • Dec 2007
    • 643
    a question
    wonder why everyone quit using magnitos and switched to msd?
  • Mopar DLM
    • Aug 2012
    • 216
    takes way to much power to turn the generator in a magneto. with the better and higher voltage batteries nowadays and better coils sparks are still strong at the end of a long race. that and ignorant chevrolet has a big enough problem with distributor turning in the block without trying to pull a magneto.
    • petesbuyin
      • 56
      Mags were not real reliable. you had to have 3 of them. 1 in the car, 1 in the trailer for spare, and 1 sent out for repair/recharge. Peak power of a motor will be the same with either a mag or MSD but MSD ignition will start easier(especially on alcohol) and be cleaner on restarts.
      A droop rule is like infield tractor tires, everyone knows it's stupid, but they still keep doing it.
        • 14303
        Only thing I ever had against them was the need to kill battery and ground them out to kill the engine.
        • perfconn
          • 3573
          Magnetos generally run a spark plug gap of .022 while MSD ignition boxes allow much larger gap.I run .040 with my engines.
          • TheJet-09
            • Jul 2013
            • 1616
            I never ran one, but don't you have to remove them if welding on the chassis? Seems like that would be a pain.
            Don't Sprint cars run them still?
            • perfconn
              • 3573
              Yes but they don't have batteries or starters.
