lot of people talking about running a heavy axle tube or birdcage on the LR i know it would be rotating weight but could you possibly run a Steel wheel on the LR and be doing the same thing? Just curious
There are reasons this is illegal as it's extremely dangerous to anyone, spectators and crews. Imagine a 100# plus wheel and tire combo breaking a rear end snout and coming off. That thing wouldn't stop for 3 miles
I made that in 2015, yes the scale is set to pounds.
Well the hub weighs about 7lbs. The rotor probably 8lbs. The flange & brgs around 3lbs. So that is 18lbs which leaves you with about 40lbs of mystery metal inside that hub! :-) It would take 98ci of lead to make 40lbs.
