Stock Flywheel / Steel Bellhousing vs reverse mount brinn set up
  • A ron
    • Apr 2014
    • 294
    Is the 10-15 lbs difference worth swapping from a standard bell to a reverse mount set up performance wise?
  • Doc88D
    • Jun 2012
    • 170
    If you go from the larger stock ring gear to the smaller bert/brinn style you will notice the difference. Specially if you have a crate engine. The bell housing and starter wont make much difference other than in your total weight numbers...
    Doc
    Facebook.com@DowdyRacing
    • A ron
      • Apr 2014
      • 294
      It is a crate engine
