Repairing Weld Wheels
  • eskew11
    • 459
    Anyone have any luck welding up a small gouge in your wheels? I’ve been trying with know luck the wheel keeps cracking beside my weld. Need some pointers. Thanks
  • Drake Racing
    • 138
    are you trying to wire weld it or tig weld? Ive welded up dozens of race wheels
    without a problem... make sure wheel is very clean, and you are using the correct rod.
    Curt Drake
    Late Model #55x
    • Punisher88
      • Nov 2014
      • 495
      And drill a hole where the crack ends. I've always been told to weld at each end of the crack to keep it from continuing. And I've never had an issue. Never welded on a wheel though.
      • eskew11
        • 459
        Curt Drake
        Late Model #55x
        Tig . What rod number should I be using?
        • eskew11
          • 459
          Curt Drake
          Late Model #55x
          I was using 5356 rod
          • fastford
            • 4059
            i have welded them with tig and mig with no problem , the advise about drilling the hole at end of crack is the best way on a crack......
