putting dry sump on my motor, i have a 40 tooth htd pulley with a bert crank pulley anyone know what drive belt number i would need? thanks for any help
Dry sump question
I always used a 580 belt with our set up.
You can take a string and use that to measure with but, 20 MM short would be just over 3/4" so you'd see about half that at 3/8" difference in pump hieght to tighten belt. So if it seems like pump needs to go up more guess how much more and use that above to guessimate how much difference in MM's you need for a belt.
