Soften fith coil up
  • hunterracing
    • Jan 2009
    • 303
    Soften fith coil up
    What affects would soften fith coil up 25 to 50 lbs but keeping it same hole on the lift arm. Could gain little more traction from center off?
    I find loss of instant traction when I go softer on rate. If driver is a throttle masher, softer can help keep tires from shocking loose.
    • hunterracing
      • Jan 2009
      • 303
      I’m not throttle smasher pretty easy into the gas. We’re on 325 just thought ask
        • 2020
        As said
        5th coil spring rate:
        1. Stiffer is faster to get traction
        2. Softer is slower to get traction
        As said stiffer can loose traction easier, but generally you have to be a real throttle smasher to notice this and usually doesn't apply to a decent driver.
        Side note* The more the 5th moves the more the rear end will shift right under throttle. The more rake in the J-bar the more this is magnified, so how noticeable it is can be somewhat dependent on J-bar to a degree.
        • hunterracing
          • Jan 2009
          • 303
          So might be best bet to keep same rate and maybe slide it back one on rearend
            With the trend of trying to keep the nose down even when on the gas, I would think most folks are looking at moving the 5th coil back to change the lift point and adjusting the spring rate (stiffer) to match the throttle feel they want. This is very much a driver feel thing. But then we could get into all kinds of debate about progressive spring versus air dump stuff which are pretty much opposite approaches but you'll have people that swear by one or the other.
            • hunterracing
              • Jan 2009
              • 303
              How bout when you tie lf up from dropping so much do you need stiffen rr to compensate so it don’t wheelie when you lower rs bars
              • Kromulous
                • 3008
                More leftside percent, or heavy LF components?
                I see a lot Touring guys run this stuff, and some struggle (Pierce). Bloomquist IMHO is all over this, and he even runs a LF tire that looks like donut (portable spare) all in an effort to get a bunch of wedge in the car so it will turn in. Then you see a bunch of the cars go way tight when the tires come in, and get hot, Richards and Bloomquist both lost races due to this.
                I guess its a combo of LS percent and heavy LF components to keep the tire down.
                Just say no...
                  Obviously there was a trend that started a while back (and is still going) to get the RF down as much as possible and the LR up as much as possible. So if you leave those two alone and you want the LF to go down, the RR must come up to do it. I'm pretty sure there are some really stiff RR setups out there winning big races right now but I could be way off. And I don't necessarily mean just a stiff RR spring.
                  • hunterracing
                    • Jan 2009
                    • 303
                    What bout the limiting strap on the lf keeping the aframe same angle at ride height and dyanmaic state
                    • a25rjr
                      • 3774
                      There was a certain car several years ago, that won a lot of races with the RR hiked up just like the LR! Im surprised it isn't more common!
                      Turn LEFT, Vote RIGHT!
                        I have had success with that, but it has to hurt entry some.
                        • TheJet-09
                          • Jul 2013
                          • 1616
                          Does anyone think a shorter lift arm can be more sensitive to spring rate changes?
                          I've moved mine back to 33" (was at 37"), and with a 350# spring it was real responsive when the track still had some traction. But I felt like it was easily blowing the tires off in the slick, so I softened it to a 325#. After doing so, it didn't quite have the same responsiveness in the mud, but felt better in the slick.
                          In addition, would there be any advantage to moving the 6th coil back as well, to maintain its distance in front of the 5th coil to around 4" or so?
                          • fastford
                            • 4059
                            if we move the shock back and soften the spring as well , we usually increase the shocks compression to slow the reaction a bit........
                            • sidewinder69
                              • Sep 2016
                              • 95
                              wouldnt limiting the lf droop make the lr drive harder and quicker but hurt overall steer capability?
