What would a guy expect if he raised the lr lower four bar up equally on both ends? So up closer to rear end on birdcage side and the same amount up on chassis?
Raising lr lower bar
17" LRU at 25 degreesOriginally posted by awesome1 View PostWhat would a guy expect if he raised the lr lower four bar up equally on both ends? So up closer to rear end on birdcage side and the same amount up on chassis?
15" LRL at 10 degrees
STD 4.5" up from center of axle
Static thrust = 17.81 degrees
dynamic at 4.4" of drop at cage
Thrust = 36.66 degree's
Index of cage = 10.05 degrees
2.274" of forward movement of cage / rollsteer
With LRL bar up 1" on cage to 3.5" below axle centerline - frame end also moved up 1"
Static = 16.87
Dynamic 4.4" of drop at cage
Thrust = 35.70 degree's
Index of cage = 11.40 degrees
2.170" of forward movement of cage / rollsteer
like above and to my point the index of the cage is fasterOriginally posted by billetbirdcage View Post17" LRU at 25 degrees
Static = 16.87
I would be careful moving the birdcage end up. I know we already have to run a bent bar on the LR lower for clearance. I’ve never moved that end, but definitely run it through it’s motion to be sure.
