'03 Mastersbilt build suggestions.
  • Krooser
    • Nov 2012
    • 3117
    #31
    Another question... on a Smackdown what spindles to use and would i have to modify the mounts to make another spindle work? I have Smackdown and S7 spindles right now...
    812-793-0827 is Mastersbilt's new phone number... also heard Tader moved to a new shop.
    As always thanks.
    Class of 2019
      #32
      I would use the S7 Krooser.
        #33
        Ditto on the S7 spindles for that car. There is no new shop. I was at the one and only MasterSbilt shop today and Tader was there.
        • Krooser
          • Nov 2012
          • 3117
          #34
          Guess you can't believe all you read on FB...but the new phone is legit.
          Got a new pair of S7 spindles for $100.00... even I can afford that. How do they different from Smackdown?
          Class of 2019
          • Krooser
            • Nov 2012
            • 3117
            #35
            Class of 2019
              #36
              I don't believe anything I read on Facebook. :-)
              The S7 has more KPI. The ride heights also go to 3-1/2" on both sides if I'm remembering correctly.
              Left side control arm lengths need to be 10-1/2 and 16-5/8 (same as original smack). Right side should be 8-1/4 and 18-5/8.
              The difference that we noticed (any it is echoed by many that started on the old smack stuff and switched to S7) is that the car is far more responsive to steering input from the center off. With the old smack spindles you kind of had to nail entry just right or you would have your hands full getting exit straight often having to use the pedals. The S7 stuff, not so much. It steers better getting off the corner. Not as good as a complete Gen-X front end but as good as the smack can get I think.
                #37
                We ran a 20" lower on the s7 setup, spaced the upper out to compensate, and moved the upper pickup points down 1". This was the 33B car Whitney drove. It drove pretty dang good on most conditions. The only hole was momentum tracks when they were dirty. I think maybe it was a caster gain issue.
                • Krooser
                  • Nov 2012
                  • 3117
                  #38
                  Sounds good to me ...
                  Class of 2019
                  • Krooser
                    • Nov 2012
                    • 3117
                    #39
                    What about steering racks? I havent heard from the PO about the parts he has to sell so now im looking at a Woodward rack another forum member has for sale... 4.0 ratio i believe. I havent used a Woodward since the 80's... they look nice but the parts are pricey but arent they all....
                    Class of 2019
                    • fastford
                      • 4059
                      #40
                      You can use about any rack if its the correct width , but sure would be nice to find one with slotted ends when working with bump steer ,
                        • 2020
                        #41
                        This is very general (if you can't get info on what is supposed to be on car)
                        The rack will typically be 1/2 to 3/4" longer (between tie rods) then the distance between the lower control arm mounting holes. Example if the lower holes are 18" apart, then a 18.25 to 18.75" length rack is generally used.
                        Rack ratio: sort of a personal preference, but typically the shorter the steering arms are you probably want a slower rack and vice versa. Ratio's have gotten a lot faster over the years and 4.0ish or faster is more the normal, but if you have long steering arms (around 5" verses 4.5") you might go up a little to a 4.4 to get similar speed as the short arm spindles.
                        For sure try to get a rack with the vertical slots, Just be aware there are different ends, some are more around the top of the shaft, some more at middle and some that are more below the shaft. Which one you need can vary depending on car. Now granted a lot of older cars don't need the slots because the tie rods are meant to be above the shaft so the old non clevis racks work fine for the most part.
                        • Krooser
                          • Nov 2012
                          • 3117
                          #42
                          The rack I'm looking at is a 3.66... I think I can retrofit the slotted ends. Definitely a plus for adjusting bump steer. Not sure on the servo spec. I'd really like a faster rack ratio... the one on my '95 is 3.3 something. I could replace the pinion on the Woodward if it's new enough... they don't service anything older than 10 years or so. Different model. I like bigger steering wheels if I can get my fat gut out of the way.
                          Class of 2019
                          • thanhhang1996zi
                            • 13
                            #43
                            Tòa nhÃ(not a nice word) Đường Việt sở hữu gồm 12 tầng vá»›i nhiều thiết bị ná»™i thất hiện đại. Đây lÃ(not a nice word) địa Ä‘iểm được nhiều công ty lá»›n tại ĐÃ(not a nice word) Nẵng thuê phòng há»™i nghị ở ĐÃ(not a nice word) Nẵng[/b] để lÃ(not a nice word)m nÆ¡i họp hÃ(not a nice word)nh, chia sẻ kinh nghiệm, giá»›i thiệu sản phẩm má»›i ra mắt thị trường.
                            Váº(not a nice word)y tại sao thuê phòng há»™i nghị ĐÃ(not a nice word) Nẵng
                            - Sức chứa người từ 20 - 99 người. ThÃ(not a nice word)ch hợp từng mục Ä‘Ã(not a nice word)ch sá»(not a nice word) dụng.
                            - Trang thiết bị phòng LED hiện đại báº(not a nice word)c nhất thÃ(not a nice word)ch hợp trình chiếu, thuyết trình các dá»± án lá»›n nhỏ.
                            - Hệ thống lọc âm hoÃ(not a nice word)n toÃ(not a nice word)n không ảnh hưởng phòng kế bên.
                            - Có nhân viên hỗ trợ giúp chuẩn bị buổi họp của KH được tốt hơn.
                            - NgoÃ(not a nice word)i ra còn có quán cafe sân thượng nhiều món ăn vÃ(not a nice word) nước uống thÃ(not a nice word)ch hợp cho các buổi phải hoạt động kéo dÃ(not a nice word)i.
                            Đặc biệt: Giao thông tiện lợi có thể di chuyển khắp thÃ(not a nice word)nh phố Đ.N.
                            Đặt chá»— cho thuê phòng há»™i nghị ĐÃ(not a nice word) Nẵng thông qua Hotline: 01207 88 0707
                            – Địa chỉ: 30 Nguyá»…n Hữu Thọ, Hải Châu, ĐÃ(not a nice word) Nẵng.
                            • Krooser
                              • Nov 2012
                              • 3117
                              #44
                              Too Can Chew to you too.
                              Class of 2019
                              • fastford
                                • 4059
                                #45
                                I guess the mods dont even look at the tech section any more......
