How to get high load on regular springs
  • Dirtmod13
    • Jan 2014
    • 245
    Rules dont allow bumps, spring rubbers, bump springs etc, so how can i go about getting the high liad numbers at 3.5” to 4.5” of travel?
  • hpontap
    • May 2008
    • 574
    Progressive rate springs?
    • Mr.Kennedy777
      • Aug 2016
      • 212
      No stacking springs either I take it? Just run conventional and have some fun with the car.
        • 14303
        Coil bind.
        • fastford
          • 4059
          Coil bind.
          yep , thats how we use to do it , was bad fast in slick , but , tricky and destructive.......
            • 14303
            Got some ideas to fix all that, but don't wanna give it all away.
            • Punisher88
              • Nov 2014
              • 495
              Maybe a hyperco uht barrel spring?
              • Dirtmod13
                • Jan 2014
                • 245
                Ideas?
                Could you on me? Been struggling after we lost bump stops, then spring rubbers, now we are Back to a single spring no other add-ons
                • Kromulous
                  • 3008
                  Make shock mounts that are dampened.
                  RF, say we mounted the shock on a jack bolt, with no threads, in-between the shock mount itself and the frame mount put a rubber Bisquit. Pull bar bushing etc.
                  You could make the entire Assy shielded so you cant see the bushing.
                  Think about a smalll bushing type pull bar, mounted on the RF, and used in the push direction. If i get time i will try to draw something up.
                  Just say no...
                  • fastford
                    • 4059
                    it would not be dampened though would it?
                      • 2019
                      Make a deflective top nut or lower spring cup and coil bind the spring, sure is cheaper then a bump or whatever (grins)
                      • smartguy13
                        • Sep 2017
                        • 28
                        Why not use a stiffer spring and lower the ride height? Generally all we care about is dynamic load anyways. I’ve seen a few Trakstar’s use this strategy with good success.
                        • 7uptruckracer
                          Because deck height rules
                          • Krooser
                            • Nov 2012
                            • 3117
                            IMCA late model rules? As a former imca promoter at two tracks I really don't have any use for them BUT they have a good set of lm rules that bring this Stoopid world of lm racing under control...
                            Now back to our regular programming.
                            Class of 2019
