Negative LR Bite?
    Negative LR Bite?
    We're on a stiffer bump stop than ever before and struggled big time with side bite. Has anyone else found that you need a significantly higher RR static load number to get side bite back in the car? This would make sense to me but in going back to what the scale numbers would look like it is going to have negative LR bite on the scales. Or should I just do what a buddy of mine said and throw away the scales and just give the car what it needs on the smasher?
    I have never run static RR. I know for a fact that it is done with success by some people. But, from a load transfer standpoint, it doesn't make good sense in my mind.
    • CCHIEF
      • Jul 2014
      • 399
      Kind of a loaded question with out track condition, assume slick with the season we are in? You running higher dynamic wheel load @ RF or bump with a higher rate? A real stiff bump rate greatly narrows the (already narrow) tuning window on RF travel. I gotten myself into a tight/loose, inconsistent situation with real stiff solid bumps. You in a crate/limited or a true super? Solid or spring bump?
      • 7uptruckracer
        I’ve heard of this in OWM can’t say I have in LM much. Except Crate. I have seen a really new car with a lot lower then traditional overall Jbar height, same rake just both pickup points about 1.5” lower. Might be to counteract what you describe. I had a DLM this weekend on a red Penske bump on a 225 with 2750 load. And had a similar issue late. Entry to middle wanted to skate but I just attributed it to the driver, let’s be honest 75% of handling issues are driver induced lol.
          Yeah I should have added this is with a crate motor. I never post setup stuff in the CLM section as it seems to be way more engine focused which is fine. And this is in slick track conditions that I'm having the NO side bite problem. Went to the stiffer bump to get more RF feel off the corner when the track is fast which worked like a charm but as soon as the track blew off we were junk. The only way I finally got some side bit in the car was to drop the lower right bar all the way down, drop the j-bar to 2" below pinion, and took all compression out of RR shock. It was actually pretty good in the slick then but this seems like a series of crutches so I'm just looking to get some balance back in the car. I've done quite a bit with dual-stage springs in the past but just not much with bumps and I'm thinking this increased dynamic wedge now has me messed up. I haven't been this far out in left field in 8 years :-)
            • 2020
            First question I'd ask is: How much if any did your actual RF travel change? If it reduced with the harder bump, then yes most likely you need to increase the static or dymanic RR load but I'd be more inclined to just adjust the dynamic personally.
              • 2020
              Matt, also since you don't run bumps much I'm guessing you may not have a travel indicator and it's a must that you have on on bumps.
              I hate the ones you buy, they always bend or get hung up and bend. I prefer to just make them with a washer and 1/4" steel rod. Then cut a piece of tubing in half to make a C and weld a tab with 1/4" hole in it and hose clamp on the upper rail. Use a simple wire tire for a marker
              See attached crappy drawing but should get the point across
              Just add the lollipop looking rod to the lower bolt for the shock with an additional lock nut so it can pivot in and out.
              Cheap and easy, just make rod long enough that when RF drops when jacking that it don't fall out of the upper hole. I add a tether to RF right at the extended length of RF shock to stop it from falling out and making reinstalling shock easier.
                My RF travel is a little less. We were on a Penske black bump and we were bottoming the nose pretty bad. At the recommendation of a very reputable setup guy, we switched to the Penske blue rather than add more packers than we already had. Fixed our bottoming problem and the nose just barely grazes the track now.
                Probably going to look into increasing RR spring rate or adding rubbers to what we have and play with that in the smasher to get a curve that looks decent.
                I have one of the travel indicators that RE Suspension sells but I haven't had it on at all this year. Sounds like I need to re-install it to see exactly where we are or use your idea, billet. I don't have any tubing but I could just use a ballast bracket and attach a piece of angle to it with a hole in it for the rod. I like the idea of a travel limiter that is more independent of the shock. Thanks for the input.
                • fastford
                  • 4059
                  before all these new set ups , ie : bumps and 2 stage , we won races with reverse wedge , never over 75# though , but with soft rt front set up , we never had any success trying it , with a heaver rt rear spring and a bunch of rt frt dive , we run more static left rear than ever before....
                    • 2020
                    On a side note: after you get the travel indicator on it, check how much you are actually compressing the bump (would be better to have some data to get a more true idea of variance on actual travel not just the max travel). Without looking up the blue penske (don't use it a lot so don't know off the top of my head) I'm not 100% on this number but for the black if you aren't in the 1.375" range of compression, you really need to pay attention to time on it and variances in those bumps as they seem to vary a ton in the lighter travels on rates a bunch now. Typically they need to be replaced about every 6 races or so, but that varies with how your using them.
                    Variances: What I mean is they vary in rates a fair amount between them as a manufacturing tolerance, mostly at travels under 1". So if you are only traveling it lightly, then the variance at those light travels can mess you up some when replacing it. I would suspect the blue is slight better about this but don't have enough data on them to say that with 100% confidence. Most of the time you can just put in your hand and squeeze and feel the difference for the first 3/8" of travel pretty easy over a new one.
                      I'll keep an eye on that. This is really kinda temporary as I would like to move to a bump spring or back to dual stage stuff but I'm giving this a try.
                      I can tell you this about the black when we ran it the one night we did. It was fast and holding the car up for about 3 laps and then the nose started plowing. The plowing got progressively worse as the heat race went on...to the point that I was having to slow corner entry way down just to get the car to turn without plowing the nose. They way it was explained to me by the same person that told me to switch to the blue was that we were just packing it down more and more as the race went on. Got rained out after heats so that was the end of that on the black.
                      With the blue, we did not seem to have this affect. Once we finally got some side bite in the car for the B-main we drove away from everybody and the nose height was consistent throughout the race on corner entry. I made an error on setup and tire selection for the feature and pulled off after about 5 laps but I could still use more side bite. Thinking I'm just going to need to work on getting more dynamic RR but I am going to start with more static. I have a myriad of ways to add drive to the car so I'm not worried to much about the low bite at this point...at least I hope not.
                      • 7uptruckracer
                        Did you have the bleed almost closed off? Sounds like it ratcheted itself down? Now I'm curious to compare my red bump to what you've been on lol.
                        • hucktyson
                          • 1903
                          What kind of zero point and 3” numbers did you have that it was packing down further and further ?
                          • a25rjr
                            • 3774
                            Back in the day, Bill Frye swore he run 60 lbs rr heavy!
                            Turn LEFT, Vote RIGHT!
                              7up,
                              Rebound was 4 clicks off full stiff per builder.
                              Huck,
                              If you mean shock numbers, the dyno sheet is showing in the 775 neighborhood for zero point and about 950 for 3 in/sec.
