Hi guys, Been away from the racing scene for a couple of years but got a chance to help a buddy with his car this last week. We went to a test session and i noticed after a couple of sessions his rr tire was extremely hot and the air pressure had risen by about 15 lbs. It explains why the car would go away after 10 laps. He says the car is real neutral in and through the center but loses drive as the race goes on. We are running 80lbs of bite without driver right now. Now i have heard two different opinions on this issue. raise the bite to load lr more. And to add more weight to the hottest tire to make it slip less. What are your opinions on this issue, or what adjustments would you try to correct the problem. Thanks for any input.
RR tire temp way hot
The lr was warm to the touch and the rr would almost burn your hand. The biggest complaint is forward drive. My thought was the same as what you just said but trying to refresh my memory. Do you think to much rollsteer will cause the rr tire to scrub to much?
Drivers are stupid...don't trust them :-)
Check to see where he had the brake bias set and if on 3-wheel. This will tell you everything you need to know about how corner entry handling really was. Especially on a slick track, drivers will always say the car was "good" on entry even if it is super tight because that feels pretty good.
Then take a closer look at your RR tire wear. Which edges are taking the biggest beating, side or front? If side, he's sliding the car too much. If front, he is likely spinning the tires due to the car being too tight in the center. Even a good driver will do this almost unconsciously and describe what you are describing. But it is a classing tight in loose off condition.
LOL I tell him that all the time. The driver is the problem. I did check and he had all 4 brakes on. The balance bar is pretty close to center. It was a really dry black slick track. The outer edges seem to have a bit more wear. I actually believe him its not to tight but it does seem to slide the rr up the track a bit before it starts going forward and thats where he complains not enough drive. He is staying on the bars the whole time because the car doesnt change hike all the way around the track. Is that a bad thing?
Let me guess...about 4 inches of rear stagger???Originally posted by jasjenh View PostLOL I tell him that all the time. The driver is the problem. I did check and he had all 4 brakes on. The balance bar is pretty close to center. It was a really dry black slick track. The outer edges seem to have a bit more wear. I actually believe him its not to tight but it does seem to slide the rr up the track a bit before it starts going forward and thats where he complains not enough drive. He is staying on the bars the whole time because the car doesnt change hike all the way around the track. Is that a bad thing?
If the car is better at 2 3/4 then that's your answer!Originally posted by jasjenh View PostAt one point he had 5 inches but i talked him down to 2 3/4 right now. But it has a lot of rollsteer i am guessing. It seems to have alot more hike then the rest of the local cars.
As a crew chief, I always took big swings at adjustments, to make sure I was going the right way. And sometimes what I thought was too big, wasn't big enough! Plain and simple, give the car what it wants!Last edited by ZERO25; 10-10-2018, 07:39 PM.
The car got a little better. Its about a mid pack car now. Just trying to figure out the next miracle adjustment. lol The rr was still way hot with the lower stagger but i forgot to check it hot. Probably was back at 5" after it gained the air pressure. I think i will add some bite and maybe take away some rollsteer and see what happens. thanks
I've made a very conscious effort this year to get my car freer on entry. I honestly don't know what else to do to it if it is indeed to tight on entry still.Originally posted by Matt49 View PostDrivers are stupid...don't trust them :-)
Not sure if bleeders are allowed where he runs. I will check into it. Kind of forgot about those, been helping mod guys for so long they were never legal in those classes. He has made a lot of changes to free the car up too, thats why i questioned the rr tire heat. I guess he isnt spinning out yet on entry yet so loosen it up some more.
