boyd or accuforce spring smasher
  • brett4
    • Sep 2010
    • 88
    what have guys had the best luck with???
  • grt74
    • Jul 2009
    • 1380
    if you can keep a good note book the boyd is just fine, I've used both and the boyd has been very consistent and repeatable, and i think they are cheaper but not cheaper as far as the way there built, nice piece for the money, and very nice people to deal with, just my opinion
    they do make an upgraded one with all the bells and whistles (memory) but i still keep notes, guess I'm just old fashioned
    • zeroracing
      • 1014
      Ultraforce has new models coming out at the dome and PRI. Including automated and improved displays. Will be in the Wehrs machine booth.
      • cjsracing
        • 836
        I like my Boyd
        • garrett87
          • Jun 2018
          • 7
          I would go with the Boyd
          • brett4
            • Sep 2010
            • 88
            will we be sorry saving the 2k and not get the fully automated model??
            • Jking24
              • Oct 2017
              • 1512
              No not in my opinion most of the people that buy the fully automated one end up with way more information than the average guy needs. And all the info is still available if you really want it the machine just doesn't record it automatically. We built our original smasher and it didn't even have a digital travel gauge we used a tape measure and we check things against our shock guys accuforce regularly and we're within two pounds of his. That 2000$can be spent in other places that will go alot further for the average racing program.
                • 14304
                You can burn up a lot of pencils for $2k. 👍
                • Jking24
                  • Oct 2017
                  • 1512
                  You can burn up a lot of pencils for $2k. 
                  And honestly other than being a little more timely, for me it helps because when i see that data list with all those numbers every .250 of travel it's to much info to process . when I'm writing each number down it helps to retain the info and visualize the curve for me
                  • Punisher88
                    • Nov 2014
                    • 495
                    I have my home made machine and use the penske spring smasher app on my phone. It gives you a curve and everything. Off of the info you put in.
                    • Jking24
                      • Oct 2017
                      • 1512
                      What is the app called ?
                      • Punisher88
                        • Nov 2014
                        • 495
                        Spring machine.
                        • grt74
                          • Jul 2009
                          • 1380
                          consistency it the main factor here
                            • 14304
                            The auto machine no more consistent than the displacement transducer. Same one you look at when doing manual. I used to do mine on a machine designed for much more elegant testing, that was automatic. Honestly, it scared me I might pull a shock apart. Lol
                            • Burke1118
                              • Mar 2018
                              • 222
                              Microsoft Excel makes a bada$$ spring smasher
