Tandem pump pulley question.
  • Krooser
    • Nov 2012
    • 3117
    I have an 18 tooth Gilmer style one piece flywheel. The KSE Tandem pump I have has a 40 tooth HTD style pulley... obviously that won't work.
    My question is what should the ratio be between the pump and flywheel or how many teeth on the pump pulley? I will be using the 18T flywheel....
    Thanks.
    Class of 2019
    • 2019
    Thanks.
    I'd say a 32 tooth upper, typically they are ran around 56% crank speed with the std 22/40 pulleys
    • fastford
      • 4059
      I generally start at 2:1 , but i have had to speed the pump up because of lower rpm drop in turn......
      • Krooser
        • Nov 2012
        • 3117
        Thanks guys... This is an older pump with some wear so I may speed it up a bit. My first go around with this style pump so your input is appreciated.
        Class of 2019
        • Jking24
          • Oct 2017
          • 1512
          If it's the old style black and gold pump get a seal kit and re seal it. also while you have it apart grind a small groove in the insulating plate between the two pump bodies otherwise when it leaks and it will ! it will pump all your power steering fluid into your fuel.
          • Jking24
            • Oct 2017
            • 1512
            I wouldn't try to over think it. the efficiency loss of a old/ worn pump is probably not a factor this kind of pump either works or it doesn't
            • Krooser
              • Nov 2012
              • 3117
              I have a seal kit.
              You're saying the groove will allow a controlled leak and relieve pressure that otherwise will get into the fuel?
              Class of 2019
              • Krooser
                • Nov 2012
                • 3117
                It has a few very light scratches in the pump in the area around the rotors... I can catch a finger nail on them but they are pretty light.
                Class of 2019
                • Krooser
                  • Nov 2012
                  • 3117
                  Found a 32T pulley...
                  Class of 2019
                  • Jking24
                    • Oct 2017
                    • 1512
                    Most pumps oil or fuel usually have some light scratches im them. Typically nothing to worry about. Especially if it's ever been run with alcohol. The alcohol dries up and leaves a sand line residue that is hard on the pumps
                    • Krooser
                      • Nov 2012
                      • 3117
                      Thanks.....
                      Class of 2019
