Lead on rear end
  • Jim11h
    • 1501
    Lead on rear end
    So started catching back up with LM tech couple years ago and there was lead mounted on lr of axle tube at the time that shortly was banned. Help me out in understanding why there, how much using, and biggest reason asking is I'm on multi leaf now and wondering if would work to add lr drive. My initial thought was no, too many leafs to wrap etc to have effect then thought more and said yes it should because the weight directly where needed and would counter act lack of rear % due to division and adding 500# to rear. Can y'all help a dumb*as out to understand? This is a mid size full frame truck (s10, Dakota, ranger) class and with some weight the rear 51.7%. Any thoughts or am I crazy day dreaming something to gain here? Thanks y'all
  • grt74
    • Jul 2009
    • 1380
    two reasons to do this, a car with alot of left side weight will have a ton of forward drive but at a cost of losing right side grip
    so if we can put it on the axle we can now have the heavy left side and rear and not lose the right side grip, the best of both worlds
    • RaceEngineer
      • Oct 2018
      • 482
      Originally posted by grt74 View Post
      two reasons to do this, a car with alot of left side weight will have a ton of forward drive but at a cost of losing right side gripso if we can put it on the axle we can now have the heavy left side and rear and not lose the right side grip, the best of both worlds
      You can still have the effects of excess lr weight on entry. But, it doesn't effect roll the way sprung left side weight does. You also have the negatives associated with unsprung weight. It's no silver bullet.
      • Highwayman
        • Jul 2017
        • 423
        Just do it!
        I was a highwayman
        Along the coach roads I did ride
        With sword and pistol by my side
        and I am still alive
        • Krooser
          • Nov 2012
          • 3117
          Why don't I see shocks mounted with the body mounted to the axle... More weight on the rear!
          Class of 2019
          • Highwayman
            • Jul 2017
            • 423
            Tis true, greater static weight, less dynamic. Kinda funny how for so long it was lighter, lighter, lighter. Whats funny is the argument that this is a trade off on handling, its not. Here's why, the LR is mostly rigid 95% of the time anymore, so there is no worry over having to deal with heavy suspension components because the LR is for all practical purposes NOT suspension, merely a prop rod holding up the rear of the car. The LR on DLM's hasn't been usable suspension since 98' when all this hook junk first got going. Nowadays its even worse since they've figured out how to keep the car up on the bars nearly all the time, except in the pits or after they flip over.
            I was a highwayman
            • RaceEngineer
              • Oct 2018
              • 482
              If your LR is still 100% rigid in 2018. You are lapped traffic.
              • fastford
                • 4059
                agreed /\ /\ /\ /\ /\ .......
                • Twenty-Five
                  • Sep 2018
                  • 22
                  Can you elaborate on this? I was under the impression locking the LR in full extension was still ideal, for consistency?
                  • fastford
                    • 4059
                    really not for consistency , instead of the old style solid chain or letting the axle tube hit the under-slung rail solid , the trend is more toward a cushion of some type , such as a spring or rubber on the chain or rail to achieve some suspension on LR at all times ........
                      • 2020
                      Too add to that^
                      Compliance should be in both directions, compression and rebound. Not just rebound like the limiting devise.
                      • Twenty-Five
                        • Sep 2018
                        • 22
                        Originally posted by billetbirdcage View Post
                        Too add to that^Compliance should be in both directions, compression and rebound. Not just rebound like the limiting devise.
                        With low speed compression control? Like a high zero number?
                        • Jim11h
                          • 1501
                          So adding weight on tube in simple terms adds rear percentage without body roll effects? Here I was thinking more magic to it like holding LR into dirt better for more grip
                          • Doc88D
                            • Jun 2012
                            • 170
                            It does also help to keep the sidewall of the tire loaded. Which in turn means you don't pick up, or un-load the LR
                            Doc
                            Facebook.com@DowdyRacing
                            • RaceEngineer
                              • Oct 2018
                              • 482
                              Yes, that weight does not leave the LR when the sprung mass is transferred during cornering. However, when your tire hits a bump, it's more mass your LR suspension has to stop from flying off the track surface and push back down.
