Wide 5 snout?
    • 2020
    Originally posted by JustAddDirt View Post
    Would this work?
    doesn't look like the GN snout.
    http://www.colemanracing.com/Hub-Sportsman-P3997.aspx
    Hmm, looks a little short on the distance between the bearings to actually be a wide 5 snout. I'm guessing since the snout is also for sell, it may be something special or different but I will check it out, Thanks.
    I pretty much got it handled how I'm gonna make the adapters, but just wanted to make sure I wasn't missing a simple hub change solution.
    • 95shaw
      • Nov 2007
      • 205
      Would this work?
      I believe Coleman called this the mini 5 hub. Uses the same bearings, shorter spacing.
      I thought someone had a hub to go on wide 5 snouts, just cannot remember who.
      Howe, maybe?
      • JustAddDirt
        • 1893
        Me 2 and for some reason I think it was Coleman. They had a long wide 5 style snout. But that was back 10 years or so ago I seem to remember seeing several of them on 9” fords with small bolt patterns
        • Krooser
          • Nov 2012
          • 3117
          Call Coleman...
          Class of 2019
            • 2020
            Thought I'd update this: Never found a hub so just made some adapters the easy way. Mounts off the drive plate and then to a 5 x 5 regular wheel pattern
            • fastford
              • 4059
              there you go , i think that was the best way for you to go , looks good to.........
