Rocket short bar brackets
    • 2020
    I use mastercam
    • shadowj38
      • Jul 2011
      • 161
      Thanks for the reply Billet. Based on that info, which combination do you think I should start with?
        • 2020
        Honestly without knowing for sure what bar lengths you was running before since you just said extensions on both. I believe most all older blue cars used a bolt in lower extension to get to the std 15" lower but some of the newer ones had one piece brackets that needed no extension.
        I'd probably go with what phenom08 said, 18.25 LRU and 15.0 LRL bar and adjust from there. I'm not a fan of the long lower bar but in some instances it works but even less often with today's set-ups.
        Double check your lengths to make sure what you had been using.
        • spiderma4
          • Dec 2009
          • 91
          billet I have a car that has 17 top 17 bottom length rods what type of track or track conditions would that work or should I go to 15 or so bottom? or maybe run a lot of angle on bottom?
          • CCHIEF
            • Jul 2014
            • 399
            Originally posted by spiderma4 View Post
            billet i have a car that has 17 top 17 bottom length rods what type of track or track conditions would that work or should i go to 15 or so bottom? Or maybe run a lot of angle on bottom?
            hijack alert!! loaded question alert!!
            • spiderma4
              • Dec 2009
              • 91
              why? am I missing something? I guess all iam asking is what conditions does the long bottom rod work in? if it works only works on a reverse bank donkey track and I don't race at one then I know not to waste my time. no one on here owes me anything if they don't what to answer the question that's fine I will plug way at it like I always do.
