Has anyone used one of these successfully? I have had it mounted and didn't get the drive I could get with the normal rocket lift arm. PM me if you need
Neuline Lift Arm
Modern dlm is all about momentum though the cornerl Old dlm racing was about drive off of the corner. Now we need the cars to make it to the middle of the corner at high speed, and you have what you have from middle off.
I have noticed a lot of folks running a series of bump rubbers in their 5th coil, replacing the spring. Funny to see, but this is essentially the same thing as the Neuline deal. Except the mount position, being down instead of up.
Although, the Neuline deal wants to control the 6th coil thru rubbers, and not a spring, that could be the difference.Last edited by Kromulous; 01-30-2019, 12:58 PM.
Just say no...
