On chassis that have the raised right rail, how much higher are they than non raised? 1", 2"? Is there any advantage to raising the rail or am I just gonna start having issues with the rack or front crossmember? '08 Masters, 2" square rail.
Raised Rail
On our masters, it seems like the crossmember and the RF front control arm bolt are what drags. The whole right side rail will drag some, but raising the cross member was the best thing we could have done.
You would need to raise the rf rail, the crossmember, and the strut crossmember to get near modern travels.Originally posted by keeks View PostOn chassis that have the raised right rail, how much higher are they than non raised? 1", 2"? Is there any advantage to raising the rail or am I just gonna start having issues with the rack or front crossmember? '08 Masters, 2" square rail.Modern Day Spec Wedge Racing
Tader sells a very nice flat crossmember that can be fitted to your car...$200.00.
You can "raise" the right rail with a 24-36" chunk of 2" square tubing by straighteng that kink in the RS rail... MastersbiltRacer can send you his drawing. I'm doing the same on my '04 Smack.Last edited by Krooser; 12-25-2019, 04:37 PM.Member of the Luxemburg Speedway Hall of Fame
Class of 2019
Thanks Krooser. Do you have a part number? Or just call Tader?Originally posted by Krooser View PostTader sells a very nice flat crossmember that can be fitted to your car...$200.00.
You can "raise" the right email with a 24-36" chunk of 2" square tubing by straighteng that kink in the RS rail... MastersbiltRacer can send you his drawing. I'm doing the same on my '04 Smack.
