Aero downforce?
    Aero downforce?
    Can you get too much, causing drag on lower hp motors?
  • grt74
    • Jul 2009
    • 1380
    throw the cog to her (gear)
    • CCHIEF
      • Jul 2014
      • 399
      Definitely, crate/lower HP cars really benefit from reduced drag, especially at bigger tracks. And they usually produce lowest lap times with highest mid corner speed....usually higher than a Super late. IDK.. lowering gear ratio to overcome drag limits top speed, but viable when track slows down. Not much of a change in ratio although.
      • fastford
        • 4059
        more rear aero down force will allow for less static weight though , i remember when the 602 class first came out , RJ was killing them with 45% rear weight because with that big rear spoiler he didnt need the static rear weight to hook it up and was right at minimum weight on scale , most everyone else at the time wanted 55% rear or more and was pulling a lot more weight... just my 2 cents...........
          • 14304
          Down force is never bad. Drag can be if you lack the HP to overcome it.
            Ronnie Lee killed them one year at Brps Nesmith races with a 8" spoiler. Where do you draw the line?
              • 2019
              The drag squares with speed increase, but a short formula is drag goes up 4 times if the speed was to double. So 100# of drag at 60MPH goes to around 400# at 120MPH.
              However as the drag increases it takes more and more HP to overcome that drag, it's roughly at a 8:1 ratio. Every time the speed doubles, the horsepower required to overcome the drag forces is increased by about eight times.
              Now keep in mind that when talking speeds under a 100MPH the HP requirement is quite low, typically the drag on a LM while high still only takes around 400HP to run in the 130 to 140MPH range. Now that doesn't mean it's going to get there quickly, but gives you an idea of what your dealing with. Typically with a super you are not concerned with drag and will accept any extra drag to increase downforce, but that is because we have way more power then the speeds we run to actually hurt you much.
              If you have a over abundance of traction and limited power then reducing drag can be an option least as far as acceleration but at a cost of maybe cornering speed.
              • 95shaw
                • Nov 2007
                • 205
                Not detracting from billet's answer.
                Is the drag number derived from the frontal area alone, or are there other factors?
                Basically, I am asking, can drag be reduced, without changing frontal area?
                Thanks.
                Btw, great post, billet.
                • RaceEngineer
                  • Oct 2018
                  • 482
                  Originally posted by 95shaw View Post
                  Not detracting from billet's answer.Is the drag number derived from the frontal area alone, or are there other factors?Basically, I am asking, can drag be reduced, without changing frontal area?Thanks.Btw, great post, billet.
                  Anything catching air adds drag. Like the spoiler.
                    • 2019
                    Thanks.
                    Drag is from entire car. Example a LM, then take the spoiler off the car. You haven't changed the frontal area (least of how I would refer to frontal area - especially if it was a regular car with front and back windshields) but will reduce the drag considerably.
                    Typically but not always (just rare) that you can reduce drag and increase down force. So most of the time to deduce drag your going to have a loss of down force.
                    Drag can be shown as a drag coefficient or in pounds of drag. While I'm far from an aero engineer, here are some typical numbers in drag coefficient you might see on various cars:
                    Best Stock auto's: .23 to .28 is really good
                    F1 car: Rumored to be as low as .7 to as high as 1.5 depending on the car and track configuration its set for.
                    LM: in the .5 range give or take some.
                    • 95shaw
                      • Nov 2007
                      • 205
                      I guess I see frontal area as anything that can be seen from the plane opposing the direction of travel. (anything the wind directly sees. Spoiler on a dirt lm would definetely be that.)
                      Spoiler hid behind the "greenhouse", not so much. The side of a lm if the car if skewed from rear steer would fall into frontal area.
                      Maybe I'm looking at it wrong.
                      • Kromulous
                        • 3008
                        Speaking of drag, and aero, anyone seen the spoilers with the bubble or concave section on the backside of the spoilers? Opinions?
                        I seen some CFD anylisis on a SLM on you tube, i think i have posted it before but they surmised that the Drivers helmet was a massive killer of air on the left side of the spoiler.
                        Also how the angled back portion of the fuel cell helped the air rise up behind the car and help with the massive suction or low pressure are behind the car.
                        Thought it was interesting, and Billets .5 drag number, wow...
                        Just say no...
                        • 95shaw
                          • Nov 2007
                          • 205
                          Hmmmm.
                          Maybe an aero reason for where some guys have their head?!!
                            A racing buddy and I were chatting recently and he said, "Aero is more important now than ever." To which I replied, "Yeah, so is gravity."
                            My point being that before humans understood what gravity was, things were falling to the ground at the exact same rate. Our understanding of things doesn't make them more important. It just means we know how to better manage the inputs to the outcomes we want.
                            • RaceEngineer
                              • Oct 2018
                              • 482
                              Originally posted by Matt49 View Post
                              A racing buddy and I were chatting recently and he said, "Aero is more important now than ever." To which I replied, "Yeah, so is gravity."My point being that before humans understood what gravity was, things were falling to the ground at the exact same rate. Our understanding of things doesn't make them more important. It just means we know how to better manage the inputs to the outcomes we want.
                              You used to not be allowed to take advantage of it as much. Now, a 4 year old car is junk because of the decking.
