Dry Sump Pump / Leave on car when not being used
  • RacerX10
    • 571
    Is there a way I can leave my dry sump pump stack on the car without it being actually used ? I'm going to drop a cheapo LS motor in the car to run some races and I don't want to pull the rear-driven dry sump pump / power steering / fuel pump stack off because I'm going to use the PS and fuel pumps, but I can't run the dry sump pump on this LS setup. Obviously I'm asking if there's a way to configure it so it won't burn up without oil circulating.
    Any ideas ?
    Thanks !
  • powerslide
    • 2696
    You will have to circulate oil. I feel like someone on here did the same and looped it or had a small tank to hold/circulate oil. And even then you are putting wear on the pump. At the price of dry sump pumps is it really worth it?
    • RacerX10
      • 571
      not really concerned about wear on the pump.
      i guess i could just put a loop line on each of the 4 stages, put some oil in each line and call it a day.
      thanks for your thoughts !
      • Punisher88
        • Nov 2014
        • 495
        In an article in this months speedway illustrated it was mentioned about a guy refusing a pump on a different motor that didn't require the last stage of the pump. And he routed it improperly and cause a giant oil fire. The manufacturer of the pump said the correct way would have been to just remove the gears from the unused stages. I dont see why this wouldn't work in your situation.
        • RacerX10
          • 571
          awesome .. thanks for your input. i'll check on that too, great idea.
          • fastford
            • 4059
            buy the shaft and the plate to take the oil pump off , not very expensive or hard to do....JMO...
            • Jking24
              • Oct 2017
              • 1512
              Agreed could probably convert the whole setup for less than 200$
              • RacerX10
                • 571
                called KSE, they quoted me $250 for the kit to convert / remove the oil pump
                • fastford
                  • 4059
                  ck with stock car products , might be cheaper or at least they use to be.......
                  • RacerX10
                    • 571
                    found their web site .. i guess "ck" is somebody I should ask for when I call ?
                    • Jking24
                      • Oct 2017
                      • 1512
                      Ck means check, and sweet also has a bracket and everything needed that is if you have a sweet pump
                      • bob1019
                        • Oct 2017
                        • 8
                        why not just take the belt off
                        • RaceEngineer
                          • Oct 2018
                          • 482
                          Fuel and power steering won't turn anymore.
                          • RacerX10
                            • 571
                            "Hey crew chief, this thing won't turn for crap and the fuel pressure is bad"
