motor question
  • hipower17
    • 643
    motor question
    just got my motor back put timing light on mark is jumping around so much can't get a true timing i have a 2 piece cloyes timing cover on it and a msd dist 8551 never had this problem before any ideals what i might be doing wrong? thanks
    • 2019
    Assume it's a roller cam, do you have a positive stop on the timing cover to keep it from flexing and letting the cam move forward/back some? Like a stop on water pump that adjusts to the cover or a billet stiff timing cover (that may be what the 2 piece cover is - stiff).
    Also check end play on dizzy and polarity on MSD box
    Few things off top of my head, besides another timing light (even a cheap non adjustable one to check it still moves a bunch)
    I also assume someone set the end play on camshaft
    • doyle hargraves
      • Jul 2009
      • 158
      Might check inside distributor. Make sure no problems with advance mechanism unless you have it locked out. Possibly slip collar not set right causing excess distributor gear lash?
      • fastford
        • 4059
        what type of timing light are you using? i had a dial type do this exact same thing you describe , went back to a old school strobe light and never had another problem......
        • Kromulous
          • 3008
          Polarity on the MSD box would be my bet.
          Just say no...
          • CCHIEF
            • Jul 2014
            • 399
            You want the light inductive pickup near the plug...not at the cap.
            • hipower17
              • 643
              it is near the plug. i use the old stroblight type, explain the polarity answer please.
              the dist is locked out. i thank you all for your suggestions
              • Jking24
                • Oct 2017
                • 1512
                If your using a pickup in the distributor and not a crank trigger the pickup wires should be purple and black to green, and orange and black to purple. If it's backwards the box acts very erratic and inconsistent
                • 96racing
                  • Nov 2010
                  • 112
                  I've had issues with the heavy racing plug wires before. I always swap out #1 plug wire with an old stock one I have laying around.
