Large diameter left rear spring?
  • Krooser
    • Nov 2012
    • 3117
    Watching a video featuring a new Warrior chassis... looked like a pretty large diameter left rear spring on the car?
    Class of 2019
  • grt74
    • Jul 2009
    • 1380
    progressive deal i would guess
    • fastford
      • 4059
      swift calls it a tornado spring , it allows a soft rate without coil binding....it basically took the place of a stacked spring and is better IMO.....
      • RaceEngineer
        • Oct 2018
        • 482
        Is it a true conical where they nest inside each other?
        • 7uptruckracer
          2.5-5.0 spring soft like 50# to circumvent deck height rules
          • CCHIEF
            • Jul 2014
            • 399
            I've tested with an 18", xx# so far, allows you to get your deck up ~12+" from static to dynamic. I don't believe it is compressed enough to nest the coils at ride height, or even compressed some below static ride height. Best application is when rules limit one spring per wheel.
              • 2020
              If you take away any more correct or linear spring rate changes due to added diameter and less bowing:
              If you are limited to a single spring and maybe a length rule, this is where is comes into play. Say you are limited to a single spring and a 16" max length rule
              Your ride load is say 600# @ 18" and you extended number is at 23"
              Say you put a normal 16" 50# spring on the car, it coil binds at say 6" tall so you have 10" of travel before bind. The spring will be coil bound before you get to you 600# ride hieght load. At 500# you would be coil bound before you got to you ride number.
              If you used a V spring like swifts, say that same spring 16" 50# V spring coil binds at 3" (coils go inside each other to allow more travel before bind) so you have 13" of travel. 50# x 13 = 650 so you can get to ride hieght and not be coil bound.
              I just made up those numbers, above.
              Remember spring rate is spring rate, so unless you doing a progressive or digressive stack where the rate is changing during travel, the V spring is no different then a single standard spring or a stack with no stop nut besides it allows more travel before bind (if you exclude any minute changes to rate from the spring bow issues).
                Its almost hard to fathom that they're getting 12.4 inches of usable stroke in a 16" spring!
                • dirtracerl77
                  • 89
                  I want to know how they are getting that much stroke from 9 inch stroke shock.
                  • 95shaw
                    • Nov 2007
                    • 205
                    Just because the rear of the deck is up 12.4 inches, does not mean the spring or shock traveled that far.
                    • fastford
                      • 4059
                      im not gone start telling numbers , but the swift spring were on is not coil bound at ride height and it is softer than any stacked combo we have ran ........
                      • RaceEngineer
                        • Oct 2018
                        • 482
                        A true conical spring could go to the height of 2 wire diameters, if a guy thought he needed that. Any spring mfg worth a lick can make you some, for a price...
                        • fastford
                          • 4059
                          i think it was well worth the 89 bucks , but as with any thing , it aint no magic bean , if you like it and tune with it and like the effect you get and the clock says you picked up , then its for you.....
                            That phrase "usable stroke" is from Swifts website.....that's a weird phrase to use when discussing a springs usable length without coil bind.
                            • grt74
                              • Jul 2009
                              • 1380
                              forgot about the swift deal, good if you need to beat the rules, seen them at pri, no big deal just beats the rules, if i can use the stack its more tunable, but there are times we kill them with a standard spring and we fall on the ground laughing, super soft is no always the best, they do it to beat the body rules is the only reason, put a 300 on the lr then when it gets slick run the nut down and preload 1-2 turns, i think most would love it but then the deck is too high, to the so called rules
