we have a 06 mastersbilt thats tight on entry no matter the track conditions? any help asap would be great thanks!
mastersbilt tight on entry
Without any setup info, all I can suggest is to make sure that if you have calipers with different size pistons that the small ones are on the right side. Also make sure your rear is square to trailed on rr and centered correctly.Modern Day Spec Wedge Racing
got a 90/10 over the rear? take it off..get your 4 bars straight with the rear hanging..then set the length of your j bar..just some suggestions without knowing what you got..
