stack spring
  • riddle28
    • Apr 2010
    • 1084
    stack spring
    new on this, on a rf setup. i run between a 350-400 standard spring with a Christmas tree bump. if i swap to a stack how do i have any clue where a good starting point is? and say you put one on and feel like the car tight in and needs more spring, do you adjust the softer spring or the heavier or the lockout point? all this is new to me and not much info out there
    It is very dependent on your car and the rest of your setup. No easy answers. You also need to know how much travel you are currently getting and what your load is at that travel. And if you're actually getting down on that bump you'll need a spring smasher to figure this stuff out.
    • riddle28
      • Apr 2010
      • 1084
      ive got a smasher 4.25 im around 2300 usually. am i just looking for a smoother curve with around the same final load #?
      • Punisher88
        • Nov 2014
        • 495
        With a 250/400 and locked out I'm typically at like 1450 to 1500 3" and 1900 to 2000 4" the that would maybe ballpark you to 2300 at 4.25. With a white with red stripe 75 bump.
        • riddle28
          • Apr 2010
          • 1084
          thanks alot punisher. i was just wanting a ballpark of what im looking for since theres so many combos
          • Punisher88
            • Nov 2014
            • 495
            You just dont want your 3" super soft with a high 4" because then it will hot that 4" with a spike and shear traction and cause a horrible push.
            • Punisher88
              • Nov 2014
              • 495
              I've always kept mine within 5 to 600 I think of what the 4" is. There's certainly people on here with more knowledge than me, and may have better info and say I'm way off. But I've never shared traction because I spike the rf load with those numbers. Not saying you cant go to a softer 3" I just haven't tried it to know how soft is too soft.
                • 14304
                700# from 3" to 4" is acceptable
                • Kromulous
                  • 3008
                  A lot of good info there.
                  I have always loved stacks, my Brother seems to drive better on them, over the single soft springs.
                  I usually ran like 600/400 (240 rate) and lock it around 7/8's to 1 inch travel. Then sometimes a small bump as well.
                  You will need a shock with some rebound to control that 600lb spring after it gets to be the primary spring thou.
                  Just say no...
                  • hipower17
                    • 643
                    what lenght would the springs be for this like for a bg rocket rt. front takes a 12" spring what lenghts of spring would you need for this. i've never worked with a stack setup. thanks for any info
                    • RaceEngineer
                      • Oct 2018
                      • 482
                      It depends on the rates you use. 6 and a 7 are fairly common. Or 6 and a 8.
                      • Twenty-Five
                        • Sep 2018
                        • 22
                        What is the theory behind using a stack vs a single spring if your 4 inch number and ride number remain the same?
                        • Jking24
                          • Oct 2017
                          • 1512
                          Short answer You can have a much softer rate initially to promote early travel without concern of coil bind. And you can tailor the curve to your needs much easier.
                          • Jking24
                            • Oct 2017
                            • 1512
                            Also just because your four inch number is the same does not mean the car will act the same if you have a high three inch the car may under travel.vs if you have a lower three inch the car may over travel all with the same 4" number. Just one example
                            • fastford
                              • 4059
                              every one has a different answer to this , to me ,and not getting into the physics of it , it has a lot to do with the track your running on , on a smooth slick track , i still think a single soft spring and a bump stop is better , on a rough track , i like the two stage ( stacked) set up . JMO
