We need to pull out the old backup car and need some advice to help get us as close as possible right out of the gate. Car is an 07 Smackdown. I have the S7 spindles and the new updated 4 bar mounts to put on it but we never raced either before. Does anyone have any baseline set up thoughts for us on this car? With the updated front end, I want to make sure I have what I need under it. Any help would be appreciated. TIA
07 Mastersbilt Smackdown Help
What is your primary car?Originally posted by smithmod View PostWe need to pull out the old backup car and need some advice to help get us as close as possible right out of the gate. Car is an 07 Smackdown. I have the S7 spindles and the new updated 4 bar mounts to put on it but we never raced either before. Does anyone have any baseline set up thoughts for us on this car? With the updated front end, I want to make sure I have what I need under it. Any help would be appreciated. TIAModern Day Spec Wedge Racing
Set your ride height at 3.5" both fronts with s7 spindles. Set rear ride heights. Measure all pin to pin.
500# of spring. 275# rf spring
150# lr spring or stack of your choice. 250# rf spring
Lf 550# at ride height pin to pin
Rf 600# at ride height pin to pin.
Lr 700# at ride height pin to pin.
Rr 330# at ride height pin to pin.
Rf 1400# at ride height pin to pin minus 3"
Rf 2400# at ride height pin to pin minus 3.75"
Rf 2800# at ride height pin to pin minus 4"Modern Day Spec Wedge Racing
500# lf spring above. And 250# rr spring
This all assumes a 2007 crossmember and may still bottom out.Last edited by MasterSbilt_Racer; 06-11-2019, 02:52 PM.Modern Day Spec Wedge Racing
I'd go with what MasterSbilt_Racer said above.
My only change would be a stiffer RF spring where I'd do a 325 or a 350, but depends on driving style, track, etc. of course.
We ran a 300 a lot. Went as high as 350 sometimes. I think that's a fair suggestion. Really depends on bump situation.Originally posted by MachineMasters View PostI'd go with what MasterSbilt_Racer said above.
My only change would be a stiffer RF spring where I'd do a 325 or a 350, but depends on driving style, track, etc. of course.Modern Day Spec Wedge Racing
I can't remember. That may be right. I'd just check bumpsteer once you are done. That would be the reason to do it.Originally posted by smithmod View PostDo I need to shim the rack and pinion up when we put the S7 spindles on? and what's the purpose for that? I have another MastersBilt driver that says they had to do this.Modern Day Spec Wedge Racing
