older mastersbilt chassis material
  • shawburn
    • 116
    I have an 04 smackdown and need to replace some tubing. Were the chassis built using mild steel or did they use anything else then? Thanks
  • Jking24
    • Oct 2017
    • 1519
    Pretty sure most of them were dom back then. Even on "chromoly" cars alot of the smaller diameter tubing is dom
      • 2020
      Agreed but some don't even use DOM on the small ones, just cheap HREW seamed tube there or on diagonal braces
      • Nesmith14b
        • Jun 2018
        • 12
        Cut my front end up last night. It has a seam on the inside. Probably CREW
        • Jking24
          • Oct 2017
          • 1519
          No argument their billet. Ne all tubing has a seam the designations can be a little misleading. The seam is different and can usually be used to identify the tubing type to a certain degree
