spring ???
  • hipower17
    • 643
    spring ???
    has anyone tried a variable rate spring like the ones qa1 has and if you have whats would be the pros and cons about them.
    thanks
    I run variable rate setups almost all the time, on various parts of the car. However, I decide what the rates are and where it changes in travel. If one of these springs matches up perfectly for you, it will work fine. Otherwise, you have just painted yourself into a corner, where you can't adjust.
    • King1
      • Jan 2012
      • 354
      The 200-550 with a 800 stacked on top on the RR with no lockout is the whoop.
        At least with your starting loads and motion ratios.
        • Jking24
          • Oct 2017
          • 1519
          Problem is you can't control the curve anytime you change static load the curve is effected and their is nothing you can do to change that
