Years ago late models ran old leaf spring suspensions or half leaf. Some ran mono leaf with coil over or coil springs on top of axle tubes. I am building one for a vintage class but would love some input on these old type suspensions. Rules won't allow a 3 ink or 4 link. What front springs, rear springs or any advice at this point will be great. Thanks in advance.
Vintage late model build
If a guy was actually trying to be as fast as possible and not just have fun or being an exhibition class type deal:
First thought would be to do half leafs and basically make it a 2 link car or a 3 link if your allowed to run a 5th arm. Then you could do a more modern type set up.
Last mono/coil car I had was a 93 Ray Allen. With steel block/alum heads, I ran 450LF, 500RF. RR was a 150spring/244 landrum mono. Lr was a 175 spring/242 landrum mono. 200 on the lift bar. A 90/10 over the rear and the RR had a leaf adjuster. My main adjustments were lead/trail on the RR and stagger. My old memory fails me at %'s though. I think they were 55 rear, 53.8 left and around 25-50 lbs bite.
