Bert Gen 2 oil blow by?
  • Burke1118
    • Mar 2018
    • 222
    Just recently I started noticing a bunch of oil around the transmission after runs and idling in the shop today, it pushed a decent amount of oil out of the over flow tube on to the shop floor. Any ideas? Hasn’t done this before and it’s relatively fresh. Thanks
  • JustAddDirt
    • 1893
    how much fluid are you using to fill?
    IIRC it is like 3/4 of a quart.
    also do you have the vent tube running vertical, then a loop at the top and running back down?
    • Burke1118
      • Mar 2018
      • 222
      Originally posted by JustAddDirt View Post
      how much fluid are you using to fill?IIRC it is like 3/4 of a quart.also do you have the vent tube running vertical, then a loop at the top and running back down?
      I have a loop, and it filled to the bottom sight glass
      • Burke1118
        • Mar 2018
        • 222
        • JustAddDirt
          • 1893
          needs to be 1/2" below fill plug or site glass.
          believe you have to much fluid in it.
          • CCHIEF
            • Jul 2014
            • 399
            needs to be 1/2" below fill plug or site glass. believe you have to much fluid in it.
            VERY probable and likely This^^
