Lightweigt battery
  • riddle28
    • Apr 2010
    • 1088
    i bought a dyna batt and it wouldnt even turn my crate over, dont recommend
    • CCHIEF
      • Jul 2014
      • 399
      So, what does your car weigh with driver, no lead? Or how much lead you adding, if any, to make weight? What engine deal in it also, wet /dry sump, iron or alum block/heads? Also what year/make car........................................ I guess the other simple question would be are you overweight without any ballast. Trying to determine if you got a heavy car, components, driver or none of the above.
      • Mopar DLM
        • Aug 2012
        • 217
        With driver it's 2356. One chunk of lead 25#. All aluminum dodge on dry sump in a 09 updated to 15 B/G rocket.
        • kiwi1955
          • Nov 2014
          • 28
          We've run the XS 1000 16v battery since 2013 with no issues. They weigh 30.8 lbs and cost $329 from Speedway. SLM with 14.5 compression, no alternator, on tender during week. I hope everyone and their families are keeping safe with this Covid-19 deal. Back here in New Zealand we have been in full lock down for two weeks.
          • racer69
            • Apr 2009
            • 249
            Most of us here are too Kiwi. State by state orders. Hope y'all are safe as well. My track promoter has the virus. My first experience with those 16Vs was back in the summer. Wow. Working with another team that ran them. So much of a difference. Not sure exact location in that rocket(seems like LR corner fairly high). But at 30.8 pounds you could do a little relocating and possibly come out pretty good
            • CCHIEF
              • Jul 2014
              • 399
              Curious...What are you trying to accomplish Mopar DLM? Less left or rear weight? Where is the ballast now? I know we favored the LR with ballast when we ran them. But also 25# toward RF in most conditions too.
              • Doc88D
                • Jun 2012
                • 170
                We've run the Dyna-Batt in 2 crate cars for 2 seasons, (3 if we get to race this year). We havent had any troubles with it. We slow charge it on fridays in the shop, Dont touch it the rest of the weekend...
                Doc
                Facebook.com@DowdyRacing
                • Mopar DLM
                  • Aug 2012
                  • 217
                  CCHIEF, With lots of down time just looking for ways to get faster. Don't need it to cut weight. Just wondering if I would get $1000 dollars worth of performance out of a battery. Losing a little left side won't hurt us. Have one 25# chunk of lead mounted under the dry sump tank
                    Cutting weight would be the only reason to buy an expensive battery?
                    • Mopar DLM
                      • Aug 2012
                      • 217
                      Going up to the 16V stuff would be another reason we would get one. Just to improve starting and ignition
                      • CCHIEF
                        • Jul 2014
                        • 399
                        Put a XS 1000 16v battery in it and forgetaboutit. You have a heavy driver? > ~200# Spend your money elsewhere!
                        • Mopar DLM
                          • Aug 2012
                          • 217
                          But then I would be spending money on something that is heavier than what is currently working in the car now.
                          • CCHIEF
                            • Jul 2014
                            • 399
                            Buy the battery that makes you happy. But if your only adding 25# of ballast..... you got something/s heavy in that car.
                            • Mopar DLM
                              • Aug 2012
                              • 217
                              What do most cars typically weight nowadays without driver in it and how much ballast on average are most having to add
                              • Jking24
                                • Oct 2017
                                • 1519
                                Depends what class crate limited or super ?
