RF Abrams shut off
  • rosco
    • 46
    RF Abrams shut off
    Looking to by an electric one. Had a manual one bleed back and lock up my brake.
    Any difference in brands?
    Found this one from Jegs with a fuse block and toggle switch ready to go
    https://www.jegs.com/i/JEGS/555/6300...xoC01AQAvD_BwE
    The Wilwood is by far more expensive and doesn’t have the switch or fuse block Any reason?
    The all star one also doesn’t come with switch or fuse block
    Our race car parts are designed with precision engineering for unbeatable performance on the racetrack.
  • fastford
    • 4059
    this is kind of odd to me because we were the opposite , we had an electric one bleed through while on and lock rt frt tire up , always used a manual after that and never had a problem , i guess its just a valve and whether it is an electric type or a manual knob type , it could still malfunction......
    • Krooser
      • Nov 2012
      • 3117
      Be sure to wire the electric one into the "run" position on your ign switch...they will kill the battery in a few days.
      Maybe the Wilwood is pricier because it is better?
      Class of 2019
      • Jking24
        • Oct 2017
        • 1512
        The willwood is the way to go its not just a line lock solenoid like others it has a built in bleed circuit so you can engage it at any time with your foot on or off the brake. I've never heard of one failing the wildwood that is
        • rosco
          • 46
          Thanks guys.
          Ya I’m 100% confident I had my foot off the brake when it happened because even though I’m a rookie I’m mechanically minded and I was thinking that would happen if I was on the brake. Even has it on jack stands to test it was working.
          When I came back in the pits I couldn’t even steer to my pit so it definitely happened on the track.
          All the electric ones say they don’t bleed through like the manual ones. But I’ll look further into the Wilwood. Thanks for your input
