Rear oversteer
    Rear oversteer
    As some setups are now calling for 0-1/2 inch of rear stagger, have we reached the maximum?
    • 14303
    Another interesting topic. A Kryptonite looks to have 2" more than an xr1. If your car doesn't settle on corner entry, do you have steer?
    • drgracer392
      • Jun 2014
      • 37
      my thoughts are with MB racer.....
      • fastford
        • 4059
        maybe not the maximum , but with the rear steer these new cars can gain , there is not as much stagger needed , there are 3 cars that i personally know and none are over 1 inch stagger , 3 different chassis and on a given night , any of the three can win , stagger was critical 15 years ago and still is to an extent , just dont take near as much , which definitely helps straightaway speed , JMO.......
        • Jking24
          • Oct 2017
          • 1512
          we've ran and won with it all over the place 5" all the way down to zero. I don't think theirs any magic their its just another variable effecting the overall handling. The main reason we got away from ruining more was tire wear on long runs especially in open motor stuff
            One of my buddies ran 2nd in a recent big race in an xr1. Shinnston said to run 0-1/2 inch!
            He had 1/2!
            • TheJet-09
              • Jul 2013
              • 1616
              How are guys going about getting that little stagger? Run a 90 (or 28.5) on the RR?
                • 2019
                Even if the LR never moves from full hike position all the way around the track, the steer is changing way more then most people would know.
                I'll leave it at that
                • TwistedFrame21
                  • Oct 2012
                  • 54
                  How much more steer are the rockets running opposed from years past?
                  • Kromulous
                    • 3008
                    Are you talking 1/2" in roll out or in diameter? Roll out, a 1/2" is only .159" in diameter, which is not much LOL.
                    We just ran our new car and i started with 1" roll out, and it turned better then any car we have had, and i couldn't believe it really, i am old and stuck in the past LOL but with these new load numbers and droop loads its a whole new game i guess.
                    Which begs the next question, how do you tighten it up more, say when it slicks off big time ? zero stagger, reverse stagger, and taking out lead or trail?
                    Just say no...
                    • Kromulous
                      • 3008
                      Another thing CJ Rayburn talked about this in his recent DoD interview, on how in the old days they ran without a lot of rear steer and turned the car with the front end. His claim was the feature times are not any faster, which i am not sure about, but it seems like the track times on a racey track are feaster, but is that due to more HP with modern engines. Something to ponder i guess.
                      Just say no...
                        • 14303
                        Poor CJ is all wet. They are wayyyy faster in the feature. The cars are at least a half second faster at Eldora than 10 years ago even though they run on the wrong rubber by rules.
                        • Jking24
                          • Oct 2017
                          • 1512
                          Agreed with regards to cj theirs alot of comparisons he makes that aren't apples to apples. In regards to the stagger theirs more Than one way to skin a cat. You can put a much stagger as you want in within reason of course and i can still make your stuff dumptruck tight. I new a very successful racer years ago that swore you only adjust stagger for the size and shape of the race track. He says the shadow and banking of the corner isn't changing why does the stagger need to. You could argue this from several angles but bottom line is they won alot of races in their time running the same stagger weather it was hammer down or dryslick and this was at a track that can be either way depending on prep that week
                          • Kromulous
                            • 3008
                            I talked to a guy, famous racer, said that is all he ever wanted to change. Adjust stagger, and that is it !
                            Unless it was wholesale lost, according to him, he would adjust stagger to what he wanted tight or loser and go.
                            I guess its all in what your used too.
                            Myself i have come to find wheel spacers are very helpful, but i do tend to agree with the set stagger for a given track but do adjust stagger here and there LOL
                            Just say no...
                            • Kromulous
                              • 3008
                              As for CJ i thought i would just throw that out there, its a point of view. CJ i think tends to be nostalgic about the past, understandable from a guy that is in his 80's and race all his life just about.
                              The new max rear steer set ups, from what i see helps get the car into the corner a lot faster. Just a slight let up in "holding' the car straight and your set in, and back all over the fuel, if the car is right. Seems like the old cars you had to roll the car in more. Anyway, thats just my observations.
                              Just say no...
