Just been chatting with a few different people and was mentioned about a soft left front spring on a bump stop. Thoughts???
LF Bump Stop?
Would I be correct in guessing this is probably what led to the first use of a LF travel limiter to keep it tied down? If not the first use, I’d say it would definitely be needed.
I started using a tether at the same time. You don't get a lot of travel on the LF anyway. I don't run on a bump there anymore. IMO the shock is more important than a tether if you are doing something outside a simple spring. The tether is more about altering weight transfer. Thats why it became popular with road racers.Last edited by MasterSbilt_Racer; 05-20-2020, 12:00 PM.Modern Day Spec Wedge Racing
I almost never test except for at the races, unfortunately. With the unlimited areas of the car to work on and no manufacturer feedback loop, I'm always on my own time table.Originally posted by Burke1118 View PostSurprised that it took someone with your intellectual prowess that long. We were having success with it in 2007.Modern Day Spec Wedge Racing
