Lf holes
  • XRNone
    • Jun 2020
    • 18
    Lf holes
    Why are the holes in the lf headlight back?
  • Burke1118
    • Mar 2018
    • 222
    Not enough air tumbling around under these cars. Too much downforce causes them to be too stuck and have too much grip. cutting holes in the nose helps with that
    • grt74
      • Jul 2009
      • 1380
      also you can use brake duct and deflect air to the radiator, summer time these things will get hot when not lifting
        Removing traction to fix handling is a bad idea.
        • grt74
          • Jul 2009
          • 1380
          i would have to agree, I've always said never take traction away, just make her turn
          • Burke1118
            • Mar 2018
            • 222
            Agreed, twas sarcasm. Has to be for cooling reasons. I am no aerodynamicist, but theres no way allowing more air to get trapped under the car can be good.
            • PushinTheLimit
              • Apr 2013
              • 465
              Gotta be a balance between handling and cooling. There just isn't much airflow going under these cars with the nose sealed off.
                No argument there. You can't win with no water in the engine.
