I'm putting my seat in my car and I have never done it before, but I have a mount on each side and I have a bracket on the back between my shoulders I have drilled my seat out for that, well my ? Where do I mount my belts, is it fine to mount them to my seat ? O my belt that goes between my legs has two ends to mount, I kno they have a name but idk what they r called, thanks
I need help with my seat
What brand of seat?Style?Chassis? Belts must be mounted to frame should have brackets in car already.Sounds like you have 6 point belts you may have to weld some new brackets under your seat for the crouch straps.
i have a regular kirky seat and a grt chassis, i have a bolt sticking up through the floor with a nut in it in front of my seat i assume he had a 5 point and thats where he had his bolted down, could i use the same brackets i use for my seat for my belts, like the brackets on the sides use for my side belts also and the one bracket i have for the back of my seat could i mount my sholder belts to it alsoIf your not sideways and all jacked up you must be playing following the leader...
