Birdcage, Bar position?
  • Kromulous
    • 3008
    STD being the 4.5" off center, both bars.
    Speaking of the LR, what happens when you move the bar up on the BC to 5.5"?
    Considering its a zero index deal, 12 to 6 on the holes, but also fwd 1" on top, 1" behind center on the lower.
    Would moving to 5.5" on the top bar give the force generated by the rear end more leverage on the top bar ?
    Reading a lot about force based instant centers, i noticed it moves the IC aft a bit and lower, but trying to figure out other side effects.
    Thanks, Krom
    Just say no...
    • 14304
    As you move a bar away from the axle centerline, you remove force from it.
    • Kromulous
      • 3008
      Thanks, MBR.
      Brings up another question LOL.
      If it loses force, moving 1 bar out (top bar), does that force get applied to the closer to CL bar (Lower)? or does it get lost or not generated by the rear end?
      Which bar would you want to amplify the load on, another question i guess LOL. Being semi-retired these days, gives me time to ponder things, very dangerous...
      Just say no...
        • 2019
        Krom, did you say that backwards? No index is with the top bar backwards and the lower bar forward. STD is more with the bars static on cage at 12/6 ish and no index is 1/7 ish
        Moving the bar on the cage up to 5.5 will significantly reduce the thrust on the entire LR suspension
          • 2019
          Blue or red lines going to black circles are the bars and the line from the intersection of those lines to the center of the axle is the thrust angle the rearend puts on the bars. This is only a drawing at ride height and dynamic will be a greater difference in thrust between the 2 (red vs blue)
          • Kromulous
            • 3008
            So you say it reduces overall thrust on the entire LR? i have been plotting out the IC on paper today, and my DWG similar to yours shows the same, so moving that IC further aft from the BC reduces the force?
            I must be confused = nothing new there. But yes, i am 1" fwd on the top bar, and 1" aft on the lower bar. So as you described i am backwards ? BCs we have a bubble on the bottom, so i just keep the bubble centered at full droop.
            Actually i checked it and am just 1" fwd on the top bar, std on the lower.
            Just say no...
              • 2019
              Frame side on left and cage on right
              There are many ways or things you can do here, but the general std no index deal is this ^^
              STD would have bars static close to 12/6 and more like 10:30/4:30 at full hike (close to over centering cage)
              No index would have bars static close to 1/7 and more like 11:30/5:30 at full hike (long ways from over centering)
              ***Note to move bars on cage you have to move on frame or change length of bar or you will move the rear end forwards/backwards and change the static wheel base.
                Anything to gain with the zero index billet, esp on a 602 crate?
                • HuckleberryB4
                  • 220
                  Maybe I'm missing the entire mechanics of zero index....but it still makes "zero" sense to me. Even after reading all of the threads/posts on it. How is a zero index setup any different than if I run a LR digressive stack that drops out to zero at full droop? Wouldn't a digressive stack be beneficial over zero index since it helps thrust the car up initially? Again, maybe I'm misunderstanding the purpose of zero index, but I just can't wrap my head around it.
                    • 14304
                    The closer you come to over indexing, the more you have mechanical antisquat. The suspension loses more and more compliance. Your tire becomes all the suspension. Your suspension becomes useless.
                    • Kromulous
                      • 3008
                      Then is mechanical anti-squat a bad thing? to some extent? I am gonna say that it is a typical race car deal, its good and bad, just what can you live with kinda thing.
                      My question is on zero index deal is how much load is on the LR tire, via bar angle (mechanical leverage) via rear end thrust applied thru the IC's or droop load?
                      IF your digressive, and zero'd out on droop load (at full hike) its all mechanical, via bar angle, applied by the rear ends force. So that would mean you would have some mechanical anti squat, i guess the secret is calculating that number and knowing where you need to be on given track conditions, or am i in left field?
                      Because i have not gotten to work well so far, but i keep trying LOL...
                      Just say no...
                        • 14304
                        When your chain is tight, there is no relative motion. That means the sum of all forces is zero. The only load is the weight you lifted.
                        Go back and watch guys hit a hole at Eldora in 2014. They may bounce 4 times. That ain't fast.
                          Tader has a pretty good video on Racer Know How.
                          Its gotta help some when at full droop, the heims on the trailing arms are very free and not bound up!
                          • Jking24
                            • Oct 2017
                            • 1512
                            To simplify it a little further. Plain and simple if the bars get close to over indexing (flipping the bird cage) the suspension goes ridged. Kepping aero out of the equation This creates max traction. on a smooth surface but on a rough surface it will cause the car to bounce and you can't have traction when your tire is off the ground. Also when the lr suspension goes ridged your spring rate is infinite you cant tune that so all these fancy digressive stacks become less or not effective
                            • hunterracing
                              • Jan 2009
                              • 303
                              What if you lower the lower bar to 5.5 will that move the thrust back fwd?
