Reverse strut vs forward strut
  • Blackmagic5
    • Jul 2020
    • 6
    What are the leading pros and cons of forward strut and reverse strut front ends. Other than the obvious of more shock travel
  • grt74
    • Jul 2009
    • 1380
    if all stays the same, ground clearance,
      • 2019
      Theoretically the car doesn't know the difference on either if the rods are put in the right locations to be exactly the same. Now this isn't always possible due to oil pan clearance or a number of other reasons.
      That being said, I'm talking when the rods are located so they both produce the same caster gain/loss, anti-dive/pro-dive, or anything else so they are exactly the same
      Front strut
      Pro:
      1. More clearance on the RF tire to turn more right without contacting the strut rod or having to route it in a manner that weakens the lower arm
      2. Easier to install in the location wanted without things being in the way: dry sump lines, oil pan, steering shaft, etc
      Con:
      1. Will hit ground easier on RF
      Rear strut
      Pro:
      1. More RF ground clearance during roll
      Con:
      1. Usually a weaker lower arm due to strut has to S shape or be less back so RF tire won't hit when turning extreme right
      2. Pain in the arse to get in right position without having clearance issue
      3. Due to shorter distance back it adds stress to the frame mount and more likely to rip or bent in a wreck
      But as I said you can have them front or back and the car won't know the difference if done correctly besides the ground clearance differences, strength, clearance issues
      • Higgy9991
        • May 2015
        • 66
        Sure seems to be the new trend across most of the chassis builders. Most use the the "s" shaped rear strut style arm as opposed to the straight strut similar to a conventional forward strut.
          • 14303
          XR1s work pretty well with a front strut.
          1) Something eventually touches the ground.
          2) You can make both ways work the same.
          3) Its probably better to make the strut in tension under braking, as opposed to compression.
          4) DLM is a monkey-see, monkey-do sport. A car wins with an STP sticker on it, they all have it next week.
