Brake lines
  • Higgy9991
    • May 2015
    • 66
    Brake lines
    Whats the opinion on the plastic brake line kits, both push lock and compression fitting style. Looking for an easier way to do brake lines, absolutely hate a double flare tool, was considering going to a vise mounted one like eastwood sells, just pull A lever to make your flair.
  • hipower17
    • 643
    we have used both steel lines and the plastic driver say he could not feel any difference.
    • Punisher88
      • Nov 2014
      • 495
      I had the braided lined on a bwrc car I bought new. Came with a kit. All braided. Never good get a solid pedal. If you switched from 3 to 4 wheel. The first corner on 4 wheel was sketchy with the extra travel in the pedal all of a sudden.
        Plastic is sketchy at best.
        • Ltemodel
          • 307
          I'm not a fan of plastic brake lines; spongy pedal; prone to heat damage. Steel brake lines should last you the life of the car if you take the time to route them properly. I love my lever-style Eastwood flare tool.
          If anyone is ever going to build more than a couple of cars, it's worth the investment. I've had leaky flares with the standard old screw type of flaring tools. I've never had a problem with the lever type.
          The biggest thing is to make sure the end is square and bur free after you cut the line I use a file and a drill bit (with my hands) to clean up the end before flaring.
          Check out my book on Amazon.
          My YouTube Channel
            • 2020
            On doing a flare: Agree with Kevin here (square on end and debur), but will add when you do the 2nd operation with the tapered wedge, DO NOT over tighten this part. Leaving extra compression available for the connected fitting to smash and seal will help a lot. 2nd would be to just use store bought length pieces (60" is the max length available) and just use unions if need longer to get from one place to another.
            • fastford
              • 4059
              I have not had my flaring tool out in years because I do exactly what billet is describing in his last sentence above....
              • Austin34471
                • May 2010
                • 174
                Just paid 180$ on Amazon for a Eastwood *style* flare tool.. did the whole car in less than an hour. So useful and easy.
                • Lizardracing
                  • 839
                  Braided lines are plastic too with a SS outer fabric.
                  I do plastic, change it every couple years. Be smart where you run it and tie it down well and it's never been an issue for me.
                    Yup. That's why a whole car with braid has a spongy pedal.
                    • Burke1118
                      • Mar 2018
                      • 222
                      Longhorns from what IVe seen have aluminum brake lines with an AN fitting crimped on the end, no inverted flair anywhere. How do they do that? Custom made?
                        • 2020
                        Your not talking about a flare nut on solid line?
                        This is typically done on a single flare (not a double flare - folded over 45 degree flare) and it generally only on stainless steel as a lesser material will break from vibration and split at the start of the flare and leak. while it will work on aluminum line, it breaks easy and is a disaster waiting to happen.
                        • Jking24
                          • Oct 2017
                          • 1519
                          I've never seen aluminum brake lines and the connection type that billet is describing is generally used for low pressure applications such as fuel line. It is not rated for high hydraulic pressure that brake lines see
