sweet rack wont turn
  • 29racin
    • Mar 2011
    • 28
    have a 18 3/4 sweet rack. I can't turn to the right but 1/4 turn. turns left Alot. any suggestions?
  • C10
    • Nov 2008
    • 359
    is this a rocket car? Also, if your tie rods are not the correct length you will have this issue as well. Its no big deal to correct just shorten the right side rod and lenghten the left. This can throw your bump steer off a bit so you will need to check that as well and possibly need to change your spacer at the rack to get it back .
    • shocker33
      • 165
      wreck....
      if you've been in any tangles, you have a bent rack shaft. Sweets are pretty famous for bending rack shafts pretty easily.
