On the straightaway, how much does the rr spring/shock compress?(from ride height)
Compression travel on the rr!
What do you think their goal should be? Wouldnt it help aero wise to get it down lower.
Some of the better cars at Eastbay were quite a bit lower. I saw a couple of rr springs that were put on before the features and they were very small.......i would say in the 150 range.
You get the rr too low, it kills aero. Air is going to get under the front. It could be because the rr tire was the only one that worked, due to compounds allowed. They were probably trying to get the car to turn off throttle.Originally posted by ZERO25 View PostWhat do you think their goal should be? Wouldnt it help aero wise to get it down lower.
Some of the better cars at Eastbay were quite a bit lower. I saw a couple of rr springs that were put on before the features and they were very small.......i would say in the 150 range.Modern Day Spec Wedge Racing
Lift arms will Lift, until something stops it.(chain, heavy tie down shock...etc) Plus lift arm is on the right side of the rear end bell, which will try to plant the rr just a little harder because it is the closest tire to lift arm.
Then there is the J bar....
Also with the rotational direction of the gear set in a QC, it is trying to plant the RR harder as well.
Lots of things not thought about going on, with the RR of these cars.I think there should be lifeguards in the genepool.
With shorter lift arm lengths being the current trend, that has a bigger effect than it used to.Originally posted by JustAddDirt View PostLift arms will Lift, until something stops it.(chain, heavy tie down shock...etc) Plus lift arm is on the right side of the rear end bell, which will try to plant the rr just a little harder because it is the closest tire to lift arm.
Lots of things not thought about going on, with the RR of these cars.Modern Day Spec Wedge Racing
