Rod Angle left to right
  • Peanut Butter Falcon
    • Oct 2020
    • 7
    Does the 4 link rod angle have a noticeable effect? At ride height my RR top bar is close to parallel but as the rear shifts under droop the RR top angles right more than the LR top bar. Is there any benefit to getting the RR bar parallel with the chassis at full droop? Birdcage and shock angles are in the correct position. I've seen a couple cars with the RR top bar mounted outside the brackets to straighten this angle (5/8" bolts) and considering if it's worth the effort?
