Dynamic front end settings
  • bcarrot28
    • Nov 2019
    • 19
    What is a good starting point on dynamic camber/castor on front end of a swartz? Wanting to check mine and make sure I'm not completely out of the ballpark.
  • drgracer392
    • Jun 2014
    • 37
    Castor we use Left +3.5 , and right +6 is our standard. Camber Left 0 to 1 positive, and right 6 to 7 negative.Make sure you set them with the car at attitude (dynamic state).
    • bcarrot28
      • Nov 2019
      • 19
      That leads to my second question. What is considered dynamic state? Rf at full travel, Lr at full extension, Rr at 2" compression and Lf fully extended?
      • Ghopper
        • May 2008
        • 234
        bcarrot28 - you have a good question. No one is racing at 2" RR compression, maybe they hit a hole for second to get that travel.
        Given many cars run similar motion ratios on 3 corners...if you wanted corner entry under braking, then RF at your ~2000-2400lbf displacement value, LF compressed -1", RR -1", LR minus 0.5-2" from full extension. This is the only time your LF has significant load.
          • 2019
          Sup, Ghopper: long time no see
          • bcarrot28
            • Nov 2019
            • 19
            bcarrot28 - you have a good question. No one is racing at 2" RR compression, maybe they hit a hole for second to get that travel.Given many cars run similar motion ratios on 3 corners...if you wanted corner entry under braking, then RF at your ~2000-2400lbf displacement value, LF compressed -1", RR -1", LR minus 0.5-2" from full extension. This is the only time your LF has significant load.
            Would that be where you would suggest checking/adjusting front suspsension? Also would you agree with the baseline settings suggested above?
            • Ghopper
              • May 2008
              • 234
              Billet - it has been a long time since I have cruised the site!
              @bcarrot28 - I would start by calling Audie Swartz. He as the most data on his cars across many customers.
              If you want tune and track your own variation, then I would only set the front end with setup rods at or near an operation condition like discussed above. This will keep you consistent in your notes and relative changes. Final camber/caster/toe number vary by tire combination and average roll angle of the chassis.
              Please hit subscribe for more ambiguous answers.
                • 2019
                My suggestion would be document what you have in the dynamic state as far as caster/camber and toe but also toe while turning. Check a few positions, like straight, 10/15 degrees left and 20 right as well as 40 and lock. That way if you make a change you can see what all you changed so you have a better idea why or what effected the difference. Meaning you may changed one thing (lets say caster) but also changed the toe when turning right, so did the change come from the caster or the toe or both. This just helps you decipher what is actually going on.
                  There sure seems to be alot of contradictory info out there on these dynamic numbers. Our shock builder is telling us to tune our rr on its 3" number. Who do we trust these days? smh
                  • Ghopper
                    • May 2008
                    • 234
                    If your shock builder is your overall setup guru, then you should listen to them as their advice only works in a package. Just don’t use the rubber travel indicator on the shock as a guide for load number setting.
                    For context, as a front end setting discussion, if the back of the car is +/-1” you won’t see much of a caster change for the tolerance we measure in.
                      • 14304
                      My rr shock rubber won't move 3" in 3 races.
                      That said,
                      I agree, you have to put the whole package together. If not, you are the guy who asks 10 racers about an adjustment and winds up doing a little of each suggestion. Those guys are lapped traffic.
                      My cars would be undrivable if the rr ever compressed 3". That doesn't mean someone else's car wouldn't work.
                      • manwplan
                        • 351
                        6-7 camber at attitude on the RF is not even close on any dirt late model
                        • Punisher88
                          • Nov 2014
                          • 495
                          I feel like they are taking into account the car is set up at attitude. Which takes camber out if your going off ground zero level. Once the car bars up your reducing the camber read from the ground. If you leave the car on a jackstand level to the ground I'd imagine it would be much higher with just the rf raised up to max travel.
                            • 14304
                            In reference to the ground, after chassis roll, that wouldn't be a terrible place to be.
                            • Ghopper
                              • May 2008
                              • 234
                              Assuming 5-7deg body roll.......wait.....Want to make this easier? Not Hoosier or anyone else is going to give you much data other than the starting number from the chassis builder (when the car is ready to load in the trailer).
                              This is the lowest cost solution: Solid rods near an operation condition and measure camber relative to the chassis. Pick a number. Go to your test track. Sweep a few RF cambers keeping other variables as fixed as possible. Rate driver subjective feedback (thumbs up/down). Keep few objective metrics (tire temp, tire pressure, wear observation, lap times preferable in segments). Steering traces would be nice, note that spring rate changes with camber. This is the best you can do without a more advanced test-rig to remove variation of vertical loads with each configuration.
                              Some shock travels attached. The RR in this example is a completely linear spring rate (225). Note that I made a scatter plot with Liftarm travel on the X, shock corner on the Y. This conceals shock velocities, but gives you an idea of where most of your time is spent. Longer liftarm numbers are under braking, shorter are under throttle.
                              (edited - this image attachment tool is not good...)
