how much toe should we be running dynamically?
dynamic toe
Lmao
Depending on lf influence on chassis at dynamic measurement, toe can be anywhere.
I'd be looking at the point where lf would has the most influence on handling.
Then tune to make most use of that influence.
Truth of the matter, is toe is low amongst priorities for handling with modern chassis setups.
If you truly think it all thru, you will find this to be true.Last edited by 95shaw; 04-09-2021, 09:59 PM.
I don't agree with that toe Is still very important for several reasons. If you don't think so take the toe out out of your car and tell me how we'll it drives. Then bolt some hard tires on and tighten your seat beltsOriginally posted by 95shaw View PostLmaoDepending on lf influence on chassis at dynamic measurement, toe can be anywhere.I'd be looking at the point where lf would has the most influence on handling.Then tune to make most use of that influence. Truth of the matter, is toe is low amongst priorities for handling with modern chassis setups.If you truly think it all thru, you will find this to be true.
Remember Bloomer a couple years ago winning with a broken lf? It didn't matter at all that race.Originally posted by Jking24 View PostI don't agree with that toe Is still very important for several reasons. If you don't think so take the toe out out of your car and tell me how we'll it drives. Then bolt some hard tires on and tighten your seat belts
I think what he is saying is that it matters little at some parts of the lap, and more at others. We see all of these pics of guys with the lf 18" off the track on corner exit. It doesn't matter at that point.Modern Day Spec Wedge Racing
I think toe is huge.
Think about it in terms of scrub and drag. When the cars are running very close lap times, this is huge.
Coming off the corner, with all four tires on the track, think about the scrub of a really large amount of toe.
Think of a tight car going into a corner, where you want more toe to get more left turning traction.
Start thinking more about dynamic toe, Ackerman and bump, and less about static toe.
As they keep narrowing the rules closer to IROC cars, small things you can do to make your car faster will be an advantage.Check out my book on Amazon.
My YouTube Channel
While I agree with your statement. One could argue that when bloomer won that consi at wheatland that he was still getting the effects of toe out from the lf due to the fact that the lf tire was still their and creating drag that the tire still steering had to have more "scrub" in it to overcomeOriginally posted by MasterSbilt_Racer View PostRemember Bloomer a couple years ago winning with a broken lf? It didn't matter at all that race.I think what he is saying is that it matters little at some parts of the lap, and more at others. We see all of these pics of guys with the lf 18" off the track on corner exit. It doesn't matter at that point.
He was getting toe out effect, when it was carrying weight. I agree with that. My point was you sure aren't going to put that much in the car on purpose, yet it drove fairly well. If it were toed in, he'd have been toast.Originally posted by Jking24 View PostWhile I agree with your statement. One could argue that when bloomer won that consi at wheatland that he was still getting the effects of toe out from the lf due to the fact that the lf tire was still their and creating drag that the tire still steering had to have more "scrub" in it to overcomeModern Day Spec Wedge Racing
I agree and you hit on my point. If it were in he would've been toast so it must matterOriginally posted by MasterSbilt_Racer View PostHe was getting toe out effect, when it was carrying weight. I agree with that. My point was you sure aren't going to put that much in the car on purpose, yet it drove fairly well. If it were toed in, he'd have been toast.
On or off gas, it pulls the car down into the corner. The more weight the lf gains compared to prior to turning, the more it will turn the car. The more toe it has, the more it turns the car.Originally posted by brett4 View PostI asked my question, thinking about corner entry on the gas, thinking if we toed our LF out a little it would help steer in on the gas.
So when you are tricycle driving up the straight with the lf 3" off the ground, the second you drop it back on the track, the car is steering itself into the corner.Last edited by MasterSbilt_Racer; 04-16-2021, 11:46 AM.Modern Day Spec Wedge Racing
