So I read that Ryan Gustin got dq'd for a vent lr upper 4bar. I'm aware of spring rods and their uses. Anyone care to shed some light on this. I'm guessing it's just another attempt to gain some compliance in the lr suspension at full hike. Within the rules. Or is this used in combination with somthing to get around the droop rule
Gustin dq
As far as I know, MLRA has no droop rule.Originally posted by Jking24 View PostSo I read that Ryan Gustin got dq'd for a vent lr upper 4bar. I'm aware of spring rods and their uses. Anyone care to shed some light on this. I'm guessing it's just another attempt to gain some compliance in the lr suspension at full hike. Within the rules. Or is this used in combination with somthing to get around the droop rule
A guy would have to see what he had to know what he was trying to do. The whole bottom can be bent, but top can't is another arbitrary, dumb rule.Modern Day Spec Wedge Racing
I know the mlra doesent have it but woo does and he's a regular.Originally posted by MasterSbilt_Racer View PostAs far as I know, MLRA has no droop rule.A guy would have to see what he had to know what he was trying to do. The whole bottom can be bent, but top can't is another arbitrary, dumb rule.
There's really only so much you can do with the droop rule anyway. It drops too far or it doesn't. You can manipulate the jack point to help you a bit. You can maybe make your limit bushing act a little digressive.Originally posted by Jking24 View PostI know the mlra doesent have it but woo does and he's a regular.
It was likely acting as a spring, as Krom is guessing. But, that could be ruled out right away based on geometry and material.Last edited by MasterSbilt_Racer; 04-15-2021, 10:54 AM.Modern Day Spec Wedge Racing
