Tire Prep
  • r.paradise06
    • Oct 2018
    • 8
    Tire Prep
    Is there a time/track condition when you should cold sipe rather than hot sipe or vise versa? Do you do vertical sipes on fronts only and horizontal/both on rears? (American racer tires on super late)
  • Burke1118
    • Mar 2018
    • 222
    TF is a cold sipe? Unplug the siping iron? lol
    • r.paradise06
      • Oct 2018
      • 8
      You're telling me you've never had to use a non-heated sipe?? Your privilege is showing...
      • Jking24
        • Oct 2017
        • 1516
        I don't know about privilege showing ,every cold sipe I've ever seen was not easy on the wallet compared to a standard heated grooving iron
          I like the ones that use std razor blades. I haven't hot siped in years.
          I'm no tire expert, but I sipe based on what I think will get the proper wear and heat. That includes depth and direction and density of cuts.
          • samgood
            • May 2018
            • 82
            I never used a sipe, too. Any reviews on national tire and battery may be? This service center network is rather wide, they must be offering cheaper prices.
            • over4T
              • Feb 2015
              • 1104
              Speedway Motors has a bit on tire siping and grooving on their tech website. It's informative for rookies to the process and you might want to check it out.
              • Lizardracing
                • 839
                Do you guys feel like needling is just as important as sipes and grooves?
                  I'm no tire guy, but I've honestly never done it and don't think I really need to. That could be because I'm too dumb to know better, who knows?
                  • CCHIEF
                    • Jul 2014
                    • 399
                    ...Needling helps a bunch if your surface soaking tires, but has other benefits
