Tight?
  • Roudy73
    • Jun 2016
    • 33
    Tight?
    What would be a good way to free the car up on the gas? Running 150 pounds of droop load.
    One would have to see your car in action to give a good answer. Easy things to try would be less rr rebound or more rf rebound.
    • TheJet-09
      • Jul 2013
      • 1616
      Maybe increase your RR load?
      If you give more detail, I'm sure you'll get some good answers.
      • Roudy73
        • Jun 2016
        • 33
        It feels like it is on the RR until it gets to the center. Then it feels like it transfers back to the LR an pushes. Will more RR load make it tight going in?
          Quite possibly. I feel like your rf is coming up too fast, but it's just a guess.
          • grt74
            • Jul 2009
            • 1380
            lengthen the rr, leave the rest of the car alone if she is traction up good, don't lift, just a burp
            • Jking24
              • Oct 2017
              • 1519
              That sounds like crate racing advice lol
              • Roudy73
                • Jun 2016
                • 33
                If I didn't lift I would end up next to the hotdogs stand... lol
                • smartguy13
                  • Sep 2017
                  • 28
                  Is your LF lifting off the ground at that point?
                  • Roudy73
                    • Jun 2016
                    • 33
                    The lf is chained up, maybe lifts at the most a inch. But it's mostly on the ground.
                    • Jking24
                      • Oct 2017
                      • 1519
                      No where near enough info here to make a call but drooping out the lf more should free the car up on initial throttle provide the chain is the limiting factor not shock valving at that point
                      • Burke1118
                        • Mar 2018
                        • 222
                        Lol @ the info given to help diagnose. pretty much like saying, "My car is too tight, I use an winters quick change rearend. Please help"
                        • CCHIEF
                          • Jul 2014
                          • 399
                          IDK, just WAY to vague. Lengthening the RR Rods 1/4" (2 turns) will free car up overall no matter what you got.
                          • CCHIEF
                            • Jul 2014
                            • 399
                            The goal is to run wide open all the way around! But we must compromise ...sometimes
                            • Roudy73
                              • Jun 2016
                              • 33
                              Have a blue gray with the standard rocket setup. I appreciate you guys taking time to give me some ideas. Just out trying to have some fun an not knock the wall down.😁😁
