So we just upgraded to a Bert Gen 2 in our Rayburn and it won’t pull in low or reverse. The tranny should be good as we got it from a Certified Rebuilder who got it directly from Darrell Lannigan and he only ran 6 races on it. I can shift it into gear just fine but when I go and push the clutch in it begins vibrating and it sounds like gears are grinding and doesn’t go anywhere. However I can put it in high gear and start it and drive off in high gear just fine. Any suggestions?
Bert Gen 2 won’t pull in low or reverse
I was kinda surprised myself but we were just playing around with it trying some stuff and I put it in high gear, gave it gas and it started and I was able to drive away, we are currently on our way to Brownstown to race and we will try and mess with the rod before hot laps, hopefully that’s the problem, thanksLast edited by MasterOfDisasterLaster; 05-12-2021, 04:57 PM.
IF YOU ARE GOING TO Brownstown,look up Mike Bechelli,he drives a #97 Late model,create Mod Etc.He is a big Bert dealer,rebuilder,he should be able to assit you.you just got greased
http://www.goddardwarrior.net
UPDATE! Mike won't be racing tonight,call him # 812-579-5670 he will be at the track.Originally posted by lazermod3 View PostIF YOU ARE GOING TO Brownstown,look up Mike Bechelli,he drives a #97 Late model,create Mod Etc.He is a big Bert dealer,rebuilder,he should be able to assit you.
thanks:you just got greased
that has a band in it that engages low and reverse.
could be an issue with the piston on the band.
and or the band stop bolt that keeps the band stationary.
one has to watch what they are doing when putting all that together.
I am less than 2 hours from you if you need assistance.
call or text 812 599 1322
JoeyLast edited by JustAddDirt; 05-13-2021, 10:13 AM.I think there should be lifeguards in the genepool.
never had this happen, and i ran the transmission for 7 years without anything but fluid changes and a tail shaft bushing and seal.Originally posted by shocker33 View Postsun gear......have had this happen many times with a gen2. Plan on 1 sun gear assembly per year.I think there should be lifeguards in the genepool.
New symptom/diagnosis, so we lost the driveshaft last night so we’re trying to diagnose this tranny while we have the driveshaft out and the car is on jackstands, if the tranny is in low or reverse the output shaft starts spinning by itself without even pushing the clutch in. However when you push the clutch in that’s when it would want to start vibrating like a freight train and won’t go anywhere.
all of the racing transmissions will do that when put in gear. it should slowly turn in low or reverse.
did you get the single lever shifter with this transmission as well?
could be a band issue, or as another poster stated the sun gear.
wandering if someone had this apart, and did not put the little black plastic guide pads in and the whole rear part of the assembly is not riding in the correct spot?
sounds like you need to have it taken apart and looked at. something is definitely wrongI think there should be lifeguards in the genepool.
Yeah, the dude we bought it from just rebuilt it, although he rebuilds them for a living so not sure how common of a mistake this is or if he would make it, possible he might’ve just overlooked it. Is it something I might be able to just take apart the tranny and fix myself or take it to someone that rebuilds them. Also it did come with a single shifter that we hooked up
i would take it back to him and have him look at it.
especially if you just bought and installed and it was a problem from the startI think there should be lifeguards in the genepool.
it's either the shifter adjusted wrong or the internal teeth are rounded on the trans. Remove shifter lever/rod and put in low or reverse (at the transmission) and apply clutch and see if it kicks it out of gear when you apply it (have someone watch the shift shaft when you apply the clutch and see if it moves/jumps. If so the gears are likely rounded and as you apply the clutch it pushes the shift arm out of alignment. If you do that test on a lift or jacks to see the trans shift shaft, apply some brakes to induce load or it may not jump out of gear.
On the shifter rod length adjustment, half a turn on the rod can be the difference in going into gear or not so it's finickyLast edited by billetbirdcage; 05-13-2021, 03:11 PM.
